Question about HTC Touch Dual Slider Smartphone
Change the time setting from 24 hour to 12 hour AM PM
How do I change the time on my htc touch win.6 from 24 hour time to 12 hour AM PM Thanks
  • 1 more comment
  • miles146 Jul 02, 2008
    How do I change the time from 24 Hour to 12 Hour AM PM on a htc touch win.6 thanks
  • vin_2290 Jan 02, 2009
    how do i change from 24-hour format to 12-hour format
  • Anonymous Jan 22, 2009
    same
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
Posted on Mar 06, 2009
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
How to change the time
Press the MODE button 3 times, the hour digits blink.
2. To set hour, turn the VOLUME wheel to obtain a desired value.
Note: Make sure the hour is set so that the AM or PM indicators are displayed correctly.
3. Press the MODE button again, the minute digits blink.
4. To set minute, turn the VOLUME wheel to obtain a desired value.
Set 12/24 Hour format
5. Press the MODE button repeatedly to enter 12/24 hour format setting mode, "H12" appears and flashing.
6. To select H12 (12Hour) or H24 (24 Hour) format, rotate the VOLUME wheel.
Exit setting mode
7. To save all settings and exit the setting mode, press the SNOOZE button.
Apr 05, 2014 | Jensen Docking Digital CD Clock Radio for...
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
How to change from Military time to 12 hour AM/PM
Glad to hear you got it taken care of. For future reference, when you ask a question it would help if you specify the make and model of the device.
Jul 29, 2012 | Lands Phones
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
I have casio Edifice E-546. The date changes at 12pm instead of 12am everyday. Can someone help/
mcdevito75 here, Many Casio Watch Models out there, I'll bet however your Casio is displaying say 1 AM rather than 1 PM as it should if the time is indeed PM after 12 noon, if so, this is why the date is changeing at 12 PM rather than, 12 AM simply re-set your casio and make sure the time of day is set at PM for time after 12 noon and AM for time anywhere before 12 NOON. Also, as you set your Casio, look for anything that may give the hint of Military time, this may be revilled as 12 hours or 24 hours, if you have anything like this, make sure it's set for 24 hours. If you have additional problems, visit a small watch repair shop in your area. Again there are many, many Casio models out there and without your watch with me it's difficult to be more accurate.
Jul 25, 2010 | Casio Edifice EFA110D-1AV Wrist Watch
How do you change the clock in a 2004 jaguar x-type
i will guess you want to change the time and not replace the unit itself,
To adjust Clock if no touch screen
1. Press and hold MODE until TA VOLUME is displayed.
2. Repeatedly press MODE until CLOCK SET is displayed.
3. To select 12 or 24 hour format, press the seek up/seek down
keys.
4. Press MODE to continue.
5. If 12 hour is selected, use # to denote AM or PM.
6. Use the keypad to enter the time in four digit format.
7. To exit, press and hold MODE until the display reverts to audio
mode.
Hope this gets you up to correct time
Cheers
Mar 27, 2010 | 2004 Jaguar X-Type
How do you change the time from military time 2 12 hour time
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold
down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military
(24 hour) time formats.
Mar 11, 2009 | Bose & Wave& Music System
Bose Clock
Feb 18, 2008 | Bose Wave Radio
Clock format
24 hour mode is all there is. Time to learn military time.
Feb 11, 2008 | Protron PD-DVR100 DVD Recorder
HTC Touch Dual Slider Smartphone Logo
1,013 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
