Question about Whirlpool 3.2 cu. ft. Plus Washer
Washer won't spin dry clothes
After the washer cycle is done the clothes are still wet and when I try to dry them they take 3 or 4 dryer times to dry. I have noticed when I put them on "High Spin" again to spin them again water shoots in the washer while the washer is trying to spin the clothes dry . I have to shut the water off manually sometimes so I can spin the clothes dry
  • 2 more comments
  • Anonymous Mar 16, 2014
    Pump clean
  • Anonymous Mar 27, 2014
    tried to put spin only on but it turns on but does not spin, clothes still wet
  • Anonymous Mar 28, 2014
    have to spin 3 or 4 times
  • Anonymous Mar 29, 2014
    Every spin cycle, even the light cycle, water spays all the clothes. When I go to pull them out they are soaked! I have to ring them out by hand before drying them. Is that what it is supposed to do...?
    Novelist:
    Champion:
  • 261 Answers
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
  • Vina King Sep 02, 2013
    Model # SAV 5910EWW
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
After the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
May 25, 2009 | Washing Machines
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
1,902 people viewed this question
Dan Webster
Dan Webster
Sal De
