Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishwasher not working
Hi, my dishwasher is not working. dont have any clue what n where the problem could be . i switched it on and could hear the motor sound but its not filling th water but after some could c the dishes becoming warm without being washed n rinsed.
  • 234 Answers
It is probably the fill valve on your dishwasher that is bad. It is hooked up to the water supply and has a plug with a couple wires.
If this is bad your dishwasher will not fill.
Posted on Apr 27, 2009
Where do I put salt.
Your question about Dishwashers "Where do I put salt" is quite myterious. I never heared about need to put salt in dishwashers. In any case, please specify the model and make of your dishwasher or other device which needs to add salt to get it working, and maybe someone might help to get a downloadable version or give you a clue how to get your manual.
Apr 25, 2015 | Dishwashers
Dishwasher faults
I'm not familiar with this type but if it has a circulating pump, it may be stuck through lack of use and causing the breaker to pop because it can't turn. Find the pump harness connector and temporarily pull it off, switch on and see if the breaker goes. If not then see if you can free the pump. Remember, electrical safety at all times! Electricity is the silent killer.
Jul 21, 2014 | Dishwashers
Hoover hnd325
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Aug 04, 2013 | Dishwashers
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
On my Dishwasher Miele G638 Plus, a red light shows up and it says PC salt, I dont know how to solve this, please help me.
Hi - its possiblily the following issues if its flashing rapidly then the electronic module maybe faulty. The other possibilties are the float switch inside the salt conatner is jammed or the reed switch for the float switch in the salt container does work.
May 30, 2011 | Miele 24 in. G638 Plus Free-standing...
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Bosch Dishwasher
Dear Saps,
Go to https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM for a pdf download for an Intruction Handbook.
If this refuses to open go to http://www.boschappliances.co.uk/boschuk2007/en/downloads/downloads.htm and follow pages to get your machines handbook.
May 17, 2008 | Dishwashers
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
81 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
