Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon sd750 How do I disassemble my canon sd750. It was dropped from about 2 feet and won't turn on now. It must be a fuse or something like that that is broke. Can you offer any suggestions?
  • 477 Answers
Send it to us for a free diagnosis this power issue is very common. we can fix for for normally 85.00 worst case 125.00 depending on the issue 85.00 replaces the fuse or mainboard.
Posted on Sep 12, 2009
I have a Canon PowerShot SD750. I dropped it and the flash not working. can i get a solution for this
Sure: Solution #1. Stop dropping it.;) Solution #2. Send it in for service. Be prepared...it will be expensive.
Oct 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
Jul 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I just dropped my Canon SD750 and now it won't turn on. Is there a reset button?....or am I out of luck?
I had a Cannon EasyShare CX7000 many years ago, had the same problem exactly, Canon cameras are not that durable when it comes to dropping it, but I have a Cannon Powershot SD1000 and I have dropped it numerous times and it still functions like it's new. three words REPLACE YOUR CAMERA. oh, and there is no reset button, you are out of luck
Aug 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My sd750 will not start up
Does the lens cover move when you do this? If it doesn't, it sounds like that might be the problem.
Jul 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Will not power on.
The most common fault on a piece of kit that has been dropped is that the solder lead will snap on the heaviest component. Usually the battery or a capacitor, resoldering will fix the problem. However disassembly is the difficult bit
Feb 03, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon powershot dosnt turn on
your camera has one of two issues.
  1. blown fuse this requires micro serface mount soldering.
  2. bad battery door switch
if you can not repair this or reather a shop do it we charge 75.00 plus shipping to fix it for you.
This is only a good price if their is no water damage and no lights come on at all.
Diagnosis is free.
Dec 30, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Nov 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Need disassembly guide for the SD750
Hi
Canon does not provide parts diagrams, even to camera repair businesses such as myself so I can't help you out with that.
I can tell you that the screws probably shorted out your fuse and that's why the camera will not turn on.
With the screws out of the sides and bottom, the two case pieces will separate at the top if you just pry them apart. As for where the screws go... hard to say, but you can probably see where they are from once you get it open.
Good luck from
Darntoothysam com
Jul 05, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
137 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
