My air condition has a water in the pan and not cooling the air
    Scholar:
  • 104 Answers
You are most likely low on freon. This would cause the system to not cool. It will also cause the indoor coil to freeze up with ice, then when the ice melts, it doesn't run down the designated path and drips outside of the unit. This will require an HVAC tech to fix.
Posted on Jul 03, 2008
2002 cadillac saville the air filter is wet with coolant why?
A wet air filter indicates a problem within the cooling system which should be addressed as soon as possible before it gets worse or leads to other system failures. Running your cooling system with a wet air filter reduces energy efficiency.
Causes of a Wet Filter An air conditioner condenses humidity from the air on its evaporator coil. The cold refrigerant circulates through the coil, and as the warm air indoors contacts it, the refrigerant absorbs the heat changing it to a gas, then back to a liquid to facilitate the cooling process. Condensation on the coils drips into a pan to be drained away through a drainpipe. The drain pan can sometimes become clogged, and the filter can eventually absorb water.
Left wet, the filter will not be able to do its job, and reduced airflow, whether from water, results in less cooling and higher energy bills. Another result of a wet filter is the creation of an environment that is ideal for mold growth, which may even spread to other parts of your system and your home. If the system was not properly installed, this could also lead to the filter becoming wet.
Remedies When the air conditioning system is not draining properly, the condensate pan and drainpipe need to be cleaned. If the clog is obvious in either the pan or the drainpipe, go ahead and remove it. Otherwise you will need to contact your HVAC contractor who has tools to clean and clear more difficult or hard to reach clogs.
When the technician evaluates your cooling system, he or she will be able to assess how well it was installed and whether it needs to be modified. The technician can also recommend the intervals between checking the air filter and scheduling professional maintenance. Regular maintanence is one effective way to prevents clogs and system malfunctions.
Aug 09, 2016 | Cadillac Cars & Trucks
Water dripping from air conditioning outlet when not switched on
When the A/C is not in use there is still condensation as your compressor will run at different times. Defrost is one, of course to cool the car is another. The condesation coming from that drain should be perfectly normal. My GMC Suburban drains all the time as well, and its usually because I leave my knob on the defrost setting even though the fan itself is off the compressor will still run as its hardwired to do so. If the compressor runs, the coil in your car will become cold resulting in the water you see. Hope this helps, thanks!
Jun 23, 2014 | Heating & Cooling
I need an owners manual for a Haier HWF05XC7-2
Do not add water to the pan under the air conditioner. Water may collect in the pan and could overflow the pan in some conditions. If you add water, you are more likely to have water spill from the pan. Air conditioners like this work by refrigeration. As the air cools, the air can't hold as much water and this condenses into the pan.
The user manual for the HWF05XC7-2 is available from Sears Parts Direct on the product support page: http://www.searspartsdirect.com/partsdirect/user-manuals/HWF05XC7-HAIER-AIR%20CONDITIONER-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0808288.pdf . Note: the manual covers two models, HWF05XC7 and HWF05XC7-2.
I hope this helps.
Jun 15, 2017 | Haier Heating & Cooling
Water dropping on air conditioner
Water is dripping on your ac from a duct? Or is the unit it self leaking Are you sure you don't need a Professional Air Duct Inspection?
If you are in the market for an Air Duct cleaning check out Air Duct Cleaning Dallas Tx.
Jun 10, 2012 | Heating & Cooling
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
I have a water leak near the front passenger sideof the motor its above the oil pan near a freeze plug but its not the freeze plug that i can see is there another freeze plug maybe behind the motor mount?
If the car is at operating temperature and the water is cool then it could just be air conditioning condensation.. Air conditioning units are usually located at the passenger side of the engine. If it is cool water it is nothing to worry about.
Dec 27, 2010 | 1995 Mitsubishi Montero
Tipically, a hot air furnce has exhaust and a cold air intake. My question is, why is one of them hooked to condensation pump that pumps water out?
Hello
In a forced hot air system you have a supply and a return.
Now with central air cond,you also have the same supply and return exept you also have an air conditioning coil that the return air goes through to be cooled,then it is blown out through the supply side to the vents in the home.
Since warm air or summer air contians water or humidity the cooling coil collects the moisture and sends it to a pan which when fills up is pumped out by a condensation pump.
Jun 01, 2010 | Goodman GMS90703BXA Heater
Doesnt cool as well as have been told
There are allot of conditions that affect the cooling, outdoor humidity, if it is between 10 and 15% humidity, then it should work well, anything above 30% outdoor humidity, it won't work. That is just nature, but duct sizing or is it a single drop? Also if you are running it in a home, you will need to open windows to allow air to excape, or it will fill the home like a ballon and then you will have reduced air flow and no cooling.
Is the pad clean? Is the full pad wet? The water level needs to be set so that when it is turned off the water level is about 1/4" below the top of the of the pan overflow pipe.
I hope this gives you a basic idea.
Sincerely,
Paul Gibson
Apr 30, 2010 | Mastercool 67680 Evaporative Cooler Air...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
