Question about Hotpoint Refrigerators
I have a hotpoint fridge freezer and the fridge is too warm
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person (or a diy person) replace one of the above items.
  • another thing that causes this is when the coils under the machine are dirty, try cleaning them and make sure the airflow under the machine is not obstructed in any way.
Posted on Jul 02, 2008
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Oct 09, 2014 | Hotpoint Refrigerators
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
Jun 03, 2012 | Hotpoint Refrigerators
Got a hotpoint ff72 fridge freezer and the fridge is not working, light still comes on but fridge is warm. freezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Hotpoint Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
My fridge is a hotpoint a fridge freezer after sitting in the garage for a while the freezer is working but the fridge is not what do i need to do
fist check the temperature of fridge,should be +2-+5c.
freezer should be between -18 to -20c.it is possible that you f/f was designed to operate between +10 to +35 degrees.most are, so as you say its in your garage/shed the ambient temp is too low for it to operate efficiently,hence fridge feels warm(compared to when it was indoors.mine is in shed with a greenhouse heater.kept at +9.....
Feb 24, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
FFA45W
Hotpoint FFA47X fridge/freezer. I have had this fridge for 3 years now and has always on regular occasions decided to defrost when it feels like it and asks me to consume all the food immediately! I have wasted massive amounts of money on food and calls to hotpoint and have had a hotpoint engineer out to sort the problem about a year ago. It goes fine for a few months..then it defrosts all over again! Its just done it again, luckily I am not using the freezer anymore it only had some peas in there. Has anyone had this problem and solved it?? I would really like to use my freezer again but am loosing patience with hotpoint! I'd be very grateful for some advice.
May 11, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Has been bleeping a while, then fridge got warm, then freezer defrosted!
So the freezing element in your fridge is broken and it's beeping because it gets below a certain temperature ?
Dec 27, 2007 | Hotpoint FFM90 Bottom Freezer Refrigerator
Open Questions:
Refrigerators Logo
82 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
