Question about Panasonic Televison & Video
Panasonic TV PT-52LCX65-K not turning on and just green led (power on) blinking. No video at all although you can hear audio. Any idea? Thanks a lot in advance.
  • Isoel Pinheiro Oct 22, 2008
    Thankyou for your anwser. I'm still having the problem and will take a look at the capacitora. I found also that I'm not getting all the needed voltages.
    thanks and take care.
Capacitors maybe...had an issue like this with another tv we had.
Posted on Oct 22, 2008
TV won't power on
Sounds like the bulb is not firing. I have the 44 inch model. Like it too. It is normal for the power indicator to blink for a minute or two AFTER the set has been turned off from running. get a phillips or panasonic TY-LA1000 bulb or a P22H 120 watt one if you can remove the old one from the housing (not very hard to do).
Mar 31, 2014 | Panasonic PT-52LCX65 44" HDTV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 52LCX65\PT Green Spot
COLOR CONVERSION IN THE MENU ,,TRY THAT,,IF NOT A NEW CABLE,,CONVERSION REALIGNS THE COLOR
Apr 17, 2009 | Panasonic PT-52LCX65 44" HDTV
PT-52LCX65-K Panasonic rear-projection LCD No Sound
My panasonic did the same thing. turns out my coaxial cable hooking up the cable from the wall was bad. Once i unhooked it from the wall, the sound popped. I wiggled it a little on the receiver end on the wall and got sound. So try replacing your cable box cord and see if it fixes it.
Dec 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Flashing Green Power on light not picture
Last Saturday evening, I experienced the exact same behavior on my Panasonic PT-52LCX65; it shut itself off without warning. I turned it back on, and it shut itself back off after about a minute, and the red "Lamp" LED on the TV began blinking.
I never got any warning message that the lamp was about to go out, but I've just replaced the lamp and now the TV is working just fine. We had to mail-order the new lamp, because neither H. H. Gregg (where I bought the TV on "Black Friday" 3 years ago), Fry's Electronics, nor Best Buy carries the part locally.
My wife found the new bulb WITH its holding apparatus for something like $120 online, roughly half what other sites were charging. We paid roughly $55 for UPS Next Day Air. The first bulb that was sent arrived broken (some UPS rep apparently thought "Fragile" meant "Shake and Drop"), but the company we ordered from cheerfully rushed us another one, and the second one was in much better shape. (Panasonic doesn't pack these replacement bulbs very well; there's a heavy bulb with a lot of air around it that Panasonic doesn't fill.)
More details available if anyone wants 'em. Hope this helps. -- ChuckE
Nov 03, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
