Question about Coleman Mach 15 Air Conditioner
RV A/C fan won't start on its own
I have a Coleman Mach 8333B series RV AC whose fan won't start on its own, I have to give it a spin to start it. Only has two capacitors. From my research I find that one is a run capacitor (connected to the compressor) and the other is a fan capacitor. Is the fan capacitor causing this problem? Should I replace it?
  • 1 more comment
  • cdoug Jul 10, 2008
    I also have that problem. I start my fan on low, I can hear the sound it wants to go, but it does not run. Then I spun the fan and then it worked. I think it might be the fan or like the other guy said it might be a bearing. Any suggestion?
  • Anonymous Apr 22, 2009
    Mine does the same thing, it'll "hum" when you turn it on, but you have to spin it to get it to run. My fan motor turns freely, so it's not the bearings. Mine has a fan start capacitor, so I figure that's the problem. I'll replace it and see.
  • Anonymous Mar 12, 2014
    I have a Fujitsu AOT24 (rest is illegible) that has had the compressor run capacitor replaced before I owned it. The wiring has overheated and I have repaired and tested it with a 35uF run capacitor. It worked OK, but I would like to confirm the rated capacitance of the capacitor.
    Novelist:
  • 161 Answers
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Posted on Jul 04, 2008
The fan starter capacitor is the problem.
It is a mallory 75 -105 uf 130 vac
Can be found at most plumbing and heating repair center or rv store
Posted on Jul 26, 2008
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
Why is my coleman mach squeaking
Our AC did this and needed bearings replaced. Cost $10 dollars to fix it. Husband did the work. Took him less than an hour to replace the bearings.
Jul 10, 2012 | Coleman Mach III Air Conditioner
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
Today the blower motor started running slowly,approx.half normal speed, both high and low setting,on our Coleman Mach 3 ac unit.I believe it is orig.in our '87 Hoilday Rambler.Any ideas would be much...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 26, 2010 | Coleman Mach III Air Conditioner
Model coleman mach 8333c8714 serie 8000 my a/c start for 2-3 minutes and than the a/c shut down but the fan still working!! after a few minutes , it want to start again but dont seem to be able to. you can...
GO TO rvcomfort.com
Jun 15, 2010 | Coleman Mach III Air Conditioner
AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Jul 15, 2009 | Coleman Mach III Air Conditioner
Coleman mach wire schematics?
GO TO
www.rvcomfort.com
Aug 04, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
2,078 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
