Question about Refrigerators
Inside refrigerator light
I just had a new refrigerator installed. Everything functions fine except that the inside light does not illuminate when the door is opened. The only reference I see in the manual is to replacing the light bulb after it burns out. In this case, it's brand new. There must be a simple explanation or fix, but I can't come up with it.
    Habit-Forming:
  • 111 Answers
Did you try replacing the bulb? The bulb could have been bad from the beginning, and if the door was never opened before being installed in your home, that would be the simplest answer.
Posted on Jul 02, 2008
Short circuit in Stratoliner passing lamps
Hi, Doug you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away from the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable free downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Need help passing lamp probs
passing lights
Yamaha XV19SX Service Manual
OEM parts for Yamaha
Yamaha STAR XV19CSX Owner Manual
Jul 30, 2012 | 2009 Yamaha Stratoliner
Gauge cluster Illumination problems
Do you have the dash light dimmer control turned off by mistake, a common cause. It is next to the headlight switch.
Jul 25, 2012 | Cars & Trucks
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The head unit functions properly except for the screen not coming on. The illuminated lights come up, but nothing on the screen.
there are probably some bad solder connections on some surface mount resistors inside of the deck itself. there are about six resistors that need to be resoldered.
Mar 11, 2011 | Kenwood KDC-X792 Car CD/ MP3 Player
Bosch B22CS80SNS sxs with no lights
You can get the manual here. on page 16 it tells you how to take off savagemode.
Sabbatical mode settings:
– Accoustic signal is switched off.
– Super cool or Super freezing
functions are ended (if activated).
– The interior illumination is
switched off.
– The light on the display panel is
reduced to basic lighting.
– Buttons are locked (except
“options” and “+” buttons).
Switching on and off:
̨ Simultaneously press “options”
and “+” buttons for 5 seconds
When switched on, [Sabbath] is
indicated on the display panel.
Good Luck
Nov 02, 2009 | Bosch Refrigerators
Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Sep 23, 2009 | Refrigerators
Lost light Whirlpool Regal refrigerator
two ways might first un plug the unit take the bulb ou and with your finger pull up on the contact inside the light socket ***** the bulb back in and try it if that doesn't work unplug the unit and with a mall screwdriver pry out the switch un plug one wire and with a meter check it to see if its working right or just replace it
Mar 12, 2008 | Refrigerators
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
