I had installed a brand new wall mounted type air conditioner - Fujitsu ASU18CL. But when I turn it on, the air is cool and very humid up to 68% humidity.
Is there someone who ever had this problem.
Thanks
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 18C1 Air Conditioner
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries...
(More)
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries seem OK in hand held unit.
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues...
(More)
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues when turned off by remote but no heat. Manual says "immediately stop operation and consult authorised service personnel". Did this, they unsure and say turn off at isolating switch for one and a half hours then try again. Third try this has worked but did it again and again two tries before starting, going okay presently. Any ideas what this code is advising?
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split...
(More)
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split ac unit
