Question about Thermador PG486GEBS Stainless Steel Kitchen Range
Flashing Lights on Thermador Oven/Range
My thermador is flashing the cooking and grilling lights in an alternating pattern, two at a time. The range works fine, but the oven & broiler are not working. Any suggestions? Thanks.
  • kellirettig Jul 05, 2008
    The cooktop is working fine, the oven will not work and has blinking lights like the problem described previously.
  • GRH92677 Jul 31, 2008
    Replacing the PC boards solves it. Not a cheap solution as the unit has to be pulled out to get access in the back. Probably a design problem in that the boards go faulty with shorts, cutting power, or anamolous reasons. I would complain to the mfg even though warranty has expired.
I HAVE THE SAME PROBLEM. MY OVEN BINKS ONCE FROM BAKE AND TWICE FROM THE OTHER LIGHT. OVEN DOES NOT WORK, ADND WE REPLACE THE CONTROL BOARD ALREADY. WHAT DOES THAT MEAN?
Posted on Jan 31, 2009
    New Friend:
We experience similar issue. What we found is that the utility company is not providing proper voltage current flowing in the house.
The control board is receiving a low voltage (or high voltage current) thus sending light signal. I suggest to have your utility company to correct the voltage (120/240). Then press the reset button.
Posted on May 28, 2013
2 Suggested Answers
SOURCE: Flashing Lights on Thermador Oven/Range
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
We have a Thermador PDR484GG with flashing blue lights!!!
one thing i found with the little blue flashing light is the main board in the back of the range not fun
Jul 01, 2009 | Thermador PDR304ZS Dual Fuel (Electric and...
Jan 31, 2009 | Thermador PGR366 Gas Kitchen Range
Thermador professional
I had the exact same problem. I read someone else turned off the circuit breaker in the electrical panel.. so I tried that. Flipped breaker off for 30 seconds and then turned back on. Oven now works perfectly as before. Go figure??
Oct 19, 2008 | Thermador PG486GEBS Stainless Steel...
Oven light
I'm Neil
No problem
Call Thermadore you have a warranty!
Please rate my soloution
Aug 24, 2008 | Thermador PGR366 Gas Kitchen Range
Blue blinking lights
I'm Neil
No problem
Check your Manuel
Call The Manufacturer you have a warranty!
Please rate my solution!
Jul 22, 2008 | Thermador PGR366 Gas Kitchen Range
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Thermador PG486GEBS Stainless Steel Kitchen Range Logo
2,233 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
