Question about Samsung Digimax D53 Digital Camera
PLEASE HELP why does my camera say low battery every time i try to put new batterys in the camera!!! they r the rite batterys and i try all different brands and it still wont work!!!!!!!!!!!!!!!! PLEASE HELP
  • 3 Answers
DEFINATLEY KNOW THE ANSWER TO THISPROBLEM FOR SURE!!! IT IS BECASUE FRO SOME REASON OR ANOTHER THIS CAMERA ISNOT COMPATABLE WITH JUST THE REGULAR AA BATTERIES...YOU NEED TO BUY SPECIAL BATTERIES FOR DIGITAL CAMERAS...EX::LITHIUM, OR RECHARGEABLE BATTERIES (I USE RECHARGEABLE BATTERIES FOR MY CAMERIA DIGIMAX D3...AND TEHY WORK GREAT!! MY CAMERA WORKDS GREAT ALL THE TIME!!) YOU CAN BUY A BATTERY CHARGER THAT COMES WITH 4 RECHARGABLE AA BATTERIES, FOR LIKE $20.00-$22.00, AT WAL-MART. THESE LAST A VERY LONG TIME!! REGULAR ALKALINE BATTERIES CAUSE A PROBLEM IN ALL DIGITAL CAMERAS BECAUSE THEY DONT HAVE ENOUGH JUICE, OR STRENTH IN THEM OR SOMETHING..I DON'T KNOW WHY FOR SURE, BUT I HAD THIS SAME PROBLEM, AND BY BUYING THE RECHARGABLE BATTERIES MADE A BIG DIFFERENCE..IT FIXED THE PROBLEM!!
Posted on Jul 08, 2008
  • 3 Answers
Well I have had similar problems with this camera model. I tried several types of batteries and changed the battery type settings from the menue too... the problem changed a little bit but it did not solve the issue. I send the camera to Samsung service but got it back with "no fault found".
as I am working in this business I could not believe that a camera like this is not able to make less than 10 pictures with one set of batteries....I gave not up.
here is what I found:
when you open the camera by releasing the little screws from the buddy you will find several connector clips holding flatcables. this clips have not been closed correctly. just close them carefully!!! with a forceps and you will have a nice camera! this work can't be done in hurry...so take your time.
Posted on Jul 07, 2008
Panasonic Lumix DMC-LS75---I have put in new batteries , yet it says " Please replace batteries" as soon as I turn it on and then switches off by itself. I have cleaned the battery terminals; it stil
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Check the contacts of the battery and in the battery compartment of the camera. They all should be clean and shiny. You can clean contacts with a dry cloth or cotton swabs. Never use anything sharp in or close by a camera.
Nov 23, 2014 | Panasonic Cameras
Cant take more than 2 pictures because it says the batteries are too low, while new batteries are in. What can i do?
Just a hunch - your camera's in-built capacitor is malfunctioning. You need to send your camera to service.
Aug 30, 2014 | GE A1250-BK 12MP Digital Camera with 5X...
I have a Canon powershot A1100is dig camera. When I try to turn it on, it reads need new batteries. even if I change the batteries. Sometimes it wont even turn on. Help
Do you using Ni-MH batteries? Canon cameras judge the battery is low power by the real-time voltage of the batteries. And the voltage of Ni-MH batteries are lower than Li-ion ones, so the camera will notice low power even there are new batteries. Try Li-ion ones and see is anything help. best wishes!!
If you will use of a special battery, please come to our online shop for digital camera batteries
Feb 21, 2011 | Canon PowerShot A1100 IS Digital Camera
Dosent turn on
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
My canon a75 continually says low battery after changing them
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jul 16, 2009 | Canon PowerShot A75 Digital Camera
Low Battery
Many Kodak brand cameras have this problem, and when I say many I mean almost all. The only solution is to try different types/brands of batteries until you find one that lasts.
Jan 17, 2009 | Kodak EasyShare C875 Digital Camera
Camera won't start Kodak batteries installed
just take off the batteries from the cam and press the power button fr few seconds then reload the batteries back to the cam... everythin wil be rite
May 22, 2008 | Kodak EasyShare CX7430 Digital Camera
Camera won't turn on
flip over the batteries...that happened to mine. also ....not all new batteries any good. make sure they wok in some thing else.
Mar 30, 2008 | Canon PowerShot A520 Digital Camera
Immediate Battery Draining
I had the same problem with my A345, it got worse and worse until now, everytime I try to take a photo the camera turns off. My brother has the same camera, his also does this.
Dec 02, 2007 | Fuji FinePix A345 Digital Camera
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Samsung Digimax D53 Digital Camera Logo
113 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
