Question about Zebra 140XiIII Plus Thermal Label Printer
Label Printing Issue
The printer is printing the packing slip label before the shipping label. How do we get the shipping label to print first?
  • 38 Answers
Send the shipping label to the printer first in your software.
This isn't a printer issue. It only prints stuff in the order received.
Steve W.
LazerTek, LLC
Posted on Jul 17, 2008
Zebra Printer prints incomplete Label.
Run a config label and see if you have the same issue. Power it up while holding cancel key is the easiest way to do that.
Oct 28, 2015 | Zebra Z4Mplus Label Printer
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Not printing
If you send a format and the label advances but does not print, then it is possible that the darkness setting is not high enough for the label/ribbon combination. Depending on what software / printer driver you are using, many times the darkness setting in the software or driver will override what is in the printer. This makes it possible to have the test print work just fine but no printing when a label format is sent the printer.
If you are sending a format and nothing at all happens at the printer, then that is a communication issue. How are you connecting the PC to the printer ?
Apr 19, 2010 | Datamax I-4308 Thermal Label Printer
Print delay between labels
This looks like its being managed in the software.
Check with the programmer.
Apr 28, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Label Printing Problems
Your problem seems to be due to worn out of rollers. Try a less glossy paper and you can find the difference.
Dec 12, 2007 | HP Officejet 4215 All-in-One Color Photo...
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
Zebra 140XiIII Plus Thermal Label Printer Logo
148 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
