Question about Nintendo DS Lite Console
Same charge problem...
I have the same problem that a bunch of people have about the ds not charging... i think it might be overcharged because the charge light comes on when the ds is turned on, and the power cord plugged in after that... so i guess try this and could u plz tell me if overcharging is the problem or if i have a fuse problem?
thanks
  • Anonymous Jul 02, 2008
    my ds would not charge either so i waited a while and used a different outlet
Wait and then plug it into a different outlet(make sure its off)
Posted on Jul 02, 2008
Overcharged the battery
Try to get a new battery off the internet somwhere (like ebay) they would be quite cheap
Dec 29, 2009 | Nintendo DS Lite
When you switch ds lite on green light comes on but nothing happens on screens dont l[ght up could anybody give some advice on how to fix
it sounds like it could of been overcharged this happens alot when the battery is over charged or a game is ejected with out powering down
Dec 11, 2009 | Nintendo DS Lite
My son's nintendo ds will not power on.
possibly, the battery went bad after overcharging...but is that supposed to be charging automatically? have the battery checked
Aug 11, 2009 | Nintendo DS Lite Console
My son's DS is frozen. We bought a generic DC
Has probably corrupted the DS's memory, small though it is. Replace the memory to unfreeze. Alternatively get angry and stamp on it. (2nd method worked on my psp, though not advised.)
Jul 07, 2009 | Nintendo DS Lite Console
Harley 03 Ultra overcharging, 16 volts
14v is not overcharging. 16v is pushing it. I'm with the regulator opinion, but I would also load test your battery. If the charging system thinks your battery is low it will try to compensate by putting out max voltage, putting additional strain on the regulator, which in turn overcharges the battery... creates a vicious cycle. Is the regulator in a spot where it gets quite warm? They have a tendency to overcharge when hot. If that is the case, try relocating it or directing more airflow over it.
Jun 26, 2009 | 2003 Harley Davidson FLHTCUI Electra Glide...
DS is stuck in charge mode when plugged in.
Your DS may have a problem reading the battery gauge, and the DS will only let the charger do its thing for a period of time. Then, if it is still connected, it may burst more charge in. This means that your DS is acting up, and your battery may have a rare (and not harmful to the DS) malfunction.
Jun 10, 2009 | Nintendo DS Console
Nintendo DS Battery Problems
ok this costs money but my idea is to maybe buy a new battery or to take it to nintendo.
the cheapest one is battery. they are sold on amazon.co.uk with a screwdriver for about £4 if it is a lite.
good luck and if all fails either get a new one or get a new charger or take it to nintendo.
Oct 31, 2008 | Nintendo DS Lite Console
Unit will not charge
I think that the problem is being caused by your actual DS not the battery. The DS might not be transmitting the power to the battery . Id return your DS and get a new one or get your money back :-)
Jul 03, 2008 | Nintendo DS Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
