Question about Panasonic SA-HE200 Receiver
SA HE200 Code F70 problem
My name is Rob from hamburg, germany.
could you help me with the repair of my receiver?
Which component do I have to replace to have rid
of this problem once and for all.
Its been in for replacement of a fuse (F70?) three times,
the time has come to do it myself.
Look forward to your reply.
Thank you
robcox@gmx.net
My name is Andrew. I got the F70 error during normal use immediately following all the sound shutting off. Other input channels seemed to work and the unit worked normally after I turned it off and on again. However, the problem repeated after about 7 minutes. The next time I tried using it it worked for about 45 minutes and then shut off and gave F70. It seemed to be running hot. I removed the cooling fan and tested it and it works. Is the unit not powering on it's fan? has it blown a fuse? seems like an odd problem. Please help me!
  • ttlvdo Jul 14, 2008
    Cool, Hopefully I can either find someone to perform this or do it myself. There seem to be many parts available from Panasonic. I may need help identifying exactly which transistor I need. Thanks again.
    Andrew
    President:
  • 624 Answers
The F70 error code is not for the replacement of a fuse. It is an error code for the microprocessor having trouble communicating.
Try leaving the unit unplugged overnight and then plug it back in again. This should clear that code.
If it does not clear the code, try doing a hard reset with the unit NOT PLUGGED IN.
You would need to use a small metal pick or small flathead screwdriver and use a jumper to ground the pick/screwdriver to the chassis of the unit. Then you slowly run that pick over each pin of the micro, thus grounding every pin one after the other. This way you are sure to ground out the reset pin.The unit must not be plugged in when you do this. It will clear all memory and settings.
Without having this unit in front of me to properly troubleshoot with the proper tools, anything told to you is only a guess. Unless the person advising you has direct experience working on these units, they can not possibly know the solution to this problem.
I work at an authorized Panasonic service center and have never seen one of these receivers with that code and all it needed was a fuse replaced.
I have seen them needing the microprocessor replaced, but that is not something you could do yourself without the very best soldering skills. The microprocessor is a surface mounted component with 80 pins and is a very difficult component to replace. You can see it on the display panel near the middle of the board.
That code is no guarentee that the micro is bad either. if it doesn't clear the code by the way I have told you above, it needs to be serviced. Like I said, nobody can troubleshoot the communication of the micro without an O-scope, schematics, and a very good knowledge of how they work.
I think the previous service center charged you for a fuse and all the did was a hard reset of the unit.
Let me know how you do with this solution and please do not rate it until we have had a chance to explore other options. I actually have repaired a couple of these before.
Dave
Posted on Jul 02, 2008
  • Dave DeGain
    Dave DeGain Jul 02, 2008
    From the service manual:
    Item
    Abnormal Status
    Error Display
    Low Frequency
    Abnormal power amp output
    F61
    Abnormal communication between peripheral LST and Micro Computer
    F70
    Power Supply Display
    Abnormal Stabilized power supply
    F76
    Guru:
  • 1,342 Answers
Posted on Jul 14, 2008
  • 2,427 Answers
And i have to add ..... nothing I think tech got this one
oh BTW there is a second way to clear and reset,,
Face the microprocessor where you ncan read the text in the propper orientation,, much like you are reading this one
count 3 pins rom the bottom and ground pins 4 and 5 then 3 and 4 using a bladed (FLAT HEAD) screw driver.. or check 3 pins from the tom then ground pins 4 and 5 then 3 and 4
I hope you understood that mess
    Genius:
  • 1,665 Answers
Just a fuse 2A/250V from link below http://www.stereo411.com/forum/viewtopic.php?f=2&t=1532
  • 4,234 Answers
There is a heat detection circuit that will shutdown the system once it starts to get too hot to prevent damage to the components. It sounds like the drive circuit for the fan is not working. This is a failure of the electronics inside the unit. This should not happen very often. If this unit has been in for repair for this problem and still has the problem, the repair was not completed. The F70 indication is the "protect mode" indication. The fact that a cool down period restores operation tells me that the problem is heat related and thus is either the fan not working (being told to run) or the heat detection circuit is defective and shutting down the system when it should not.
This should be easily found with the proper test equipment and the unit on the test bench. If you are not happy with your local servicer, try changing the transistor that is located close to the fan connector. That should be the fan "switch" that may be defective. Also, check to see if the fan is actually turning at all. You have tested the fan itself, we now need to verify that the driver circuit is functioning.
Keep us posted on your progress.
Dan
    Master:
  • 848 Answers
I think your having some input problem that is very high voltage so that fuse is getting blowed .....your voltage regulator might not work properly ...
What causes f70 code
This may be blown fuze. This is an informative forum. Read answer one-third down page. Hope this helps Technics stereo receiver F70 error code CK5 Forums
Mar 11, 2015 | Technics SA-DX750 Receiver
Panasonic SA-HE200 no left front channel A or B, or headphone
Hello
It preamplifier section has the trouble. If you want to do it by yourself at home, you must have through knoledge in electronics, as this section inside is a very coplicated one, even a well experienced technican too, take a long time to troubleshoot, and locate the faulty component or components. OK.
Feb 06, 2012 | Panasonic SA-HE200 Receiver
Panasonic AV Control Receiver SA HE7 error code F70
solution about f70 on my amplifier to remove
Jun 07, 2011 | Panasonic SA-HE7 Receiver
Overload on Receiver-SA-HE200
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} you many have a fraid wire or if you playing the unit to loud and overload the amp this may cause it to go to protect. Also is the the receiver properly vented. If it get to warm the receiver will also go into the protect mode. hope this helps
May 25, 2010 | Panasonic SA-HE200 Receiver
Firt a error F70 and overload
a error F70 in my panasonic sa-he7
Oct 14, 2009 | Panasonic SA-HE7 Receiver
Error F70 as you have found out is a blown 1.25Amps fuse. To my knowledge, Germany uses 220 Volts 50 Hz. Pls verify if the Panasonic is rated at 220 or 240 Volts and 50Hz or 60Hz. The frequency or voltage settings might have to be set appropriate to your local settings.
Alternately, It may be that your fuse is rated to be a fastblow type meaning that it will instantaneously burn out on certain occasion even under normal usage. A quick but dirty solution is to use a slowblow fuse. As the name implies, it is still a fuse and it will still burn out if anythings goes wrong. However, it may take a bit more time before reacting. The time difference would spell the difference between constantly changing your fuse or allow more time before it blows (if it will really ever blow). There is however of course the possibility that if and when something is really wrong inside the Panasonic, the fuse being a slowblow may hesitate a bit longer and allow more damage.
It is normal for devices such as these to have a higher initial current than the running current and fuses are rated normally on a compromise between the two.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 16, 2008 | Panasonic SA-HE200 Receiver
Video Issue with SA-HE200
You might want to re-wire your system so that the SA-HE200 only handles audio for the various components. Run video lines directly to the TV/Monitor. Always use the best (most advanced) matching cable type between the two.
I always setup my systems like this anyway. You end up using less and shorter cable runs and often get to use a video cable type the audio receiver doesn't support.
Mar 22, 2008 | Panasonic SA-HE200 Receiver
Panasonic SA-HE100 5.1 system error code F70
According to the operating instructions, you must take it to a repair facility. There are no troubleshooting suggestions for this problem in the manual.
Dec 15, 2007 | Panasonic SA-HE100 Receiver
Intermittent F70 Error
F70 interrmintent problem caused by (Ic-current) interupted, supply for cpu, Q1702 (emitter point) high resistant to IC1701, suggestion- connect a wire between these component due to pcb track poor contact.
Aug 21, 2006 | Panasonic SA-HE7 Receiver
Panasonic SA-HE200 Receiver Logo
1,757 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
