Question about Samsung SGH-t329 Cellular Phone
Sorry! my it be posible to help samsung shg t219 after unlock at top screen shows locked signal and searching signal not getting. Regards abdi
  • 20 more comments
  • abdi199 Jul 03, 2008
    still there is nothing success to solve the problem.
    Did u forget the phone model "samsung SGH-T219" that it means u sent me like try and error codes!!!!
    hey!!! phone allready is opened but not getting signal wat the hell.
    looool is that all in all, unlocked but no signal okey.
    Thaks
    bye
    no rating, no solution and not experts i see.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    the only thing i am asking is how to get signal Samsung SGH-T219 not for lock or unlock.
    did u get my point!!!
    no signal samsung SGH-T219
    one operator that i want to use is only the signal searching my samsung SGH-T219 but others are normal,
    how it works some operators get signal my samsung SGH-T219 if pins broken.
    if i search the network it gets one operator only where here are three operator so why cause to miss two of them???
    just i am at system that i don't get the signal even searching got nothing where i see the operator far from me!!!!
    Please do u think enough to clean with alcohol or wats to add more network pins???
    someone who helping the handset opening says it wants to add some network pin, and we don't get pin in this area.
    please how i can get nokia model 3110c security code if i changed and forgot??
    The IMEA number is 359539/069530/7
    i see digit on the screen so nothing at all.
    sorry! i gave wrong imei number, now is 359539010685307
    nothing it changed the command and i see the digit on the screen,
    Code error.
    i am waiting ur help,
  • abdi199 May 11, 2009
    hello, i forgot memory card password how can i reset???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 544 Answers
Your network lock is still active
Enter #7465625*638*00000000#
00000000 will be display as - - - - - - - -
Network lock should now be inactive
Posted on Feb 05, 2009
The passwords still doesnt work. is there any other way
Posted on Sep 23, 2008
  • 983 Answers
Put in the sim card that the phone is not meant to work with
enter
*#9998*3323#
press exit
phone resets
wait for the phone to reboot
& the phone will work with the new sim
your problem will be solved
any doubts reply me
i am always here to assist you
thank you
bye
please rate my solution
Posted on Jul 02, 2008
  • 27 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 03, 2008
    try these codes too
    *2767*2878#
    *2767*3855#
    any doubts reply me
    thank you
    bye
    try *2767*688#
    #*7337#
    #7465625*638#
    actually samsung lock codes works with almost all model with some exceptional models
    so
    try this too
    *2767*2878#
    *2767*637#
    if these codes also doesnt work means you must take your cell for flashing that s all....
    installing new firmware solves the problem ..
    sorry to hear this you must get installed with the new firmwares ...
    the codes are not compatible to your phone to unlock ...
    thank you
    bye
    hey ok cool .. rate my solution fixya then...
    whatever you say but you got it unlocked right then you should rate my solution ...
    that s it i can tell ... others your wish ...
    oh god now got it ... you must have told it before
    just open your handset inside there will be the network pin if that will not be in contact with the circuit board means you will not get the network ...
    i think it is not in contact just make it to contact the circuit board ...
    that s it you will get the network ...
    this is the solution buddy ... did you got it now .. just do that you will get it ...
    if the network pins are broken means also you will not get the signal ...
    just first open it & check inside ...
    ok fine you have the other network sim card then just insert it & then try to search the network .... i think it will be successful ...
    if same problem persists then the above said is the case there will be loose contact in the network pins just open it & fit that correctly ...
    you look this normal because you are thinking that you handset is able to search the other network but actually it is searching but if you insert the sim card of the other network provider you will get the signal but if the network is of full signals you may get some 1 r 2 points this is because of that loose contact inside
    this is happening because as the pins are in loose contact it is not touching the board fully so it is not able to search the frequency of your network provider ..
    only it is searching the networks which has full strength right now in the place where you are staying ...
    if the signal is in full strength also it will not show the full signals it will show half of the signal that s all ...
    if dont believe this try to go to some other area where the signal strength is full & try searching the network you will get the network but it will not be of full strength you will get half of it that s all ...
    that s what i told na if the network pins are not in correct contact with the circuit board it happens like that ... it will able to search the some frequencies which are higher ..
    but it couldnt able to search the lower frequencies ...
    just open the handset if you are good at opening then take of the network pins & check the point where it touches the circuit board clean it with some alcohol solvents like spirit & just fit it correctly after that you will be able to get all the networks ....
    this solves your problem ....
    i think now you can rate the solution ....
    then open it & fix it as i told
    read the above comments correctly you will understand what you have to do
    no need to add anything if the network pins are not partially broken ......
    just cleaning is enough if the network pins are in good condition
    hey see buddy if you are asking the technician means they will tell like that only to make money .....
    it is a simple problem ...
    if the pins are not broken then no need to change anything just opening & cleaning & correctly fitting so that the pins touch the circuit board is enough this solves your problem .....
    hey buddy now you must & should rate my solution fixya ...
    because nobody will assist you this much ....
    if you need this much reply you go for the premium assistance here in fixya for which you must pay 15$ something like that ..
    i have assisted you this much long ... atleast do that rate me fixya ..
    this is simple problem buddy ... you can do it by yourself ....
    i would have given you the code to unlock the security code but you didnt rate me fixya ... instead you rated me helpful
    so i will not give ..
    if you want means post another comment & rate me fixya
    give me the IMEI number i will give you the unlock code
    try this code
    *#7246651247#
    surely it will work 99% ....
    that will reset the security code to default code ...
    try it & reply me
    dail *#06# and tell me the IMEI number again
    *#6425231214#
    this is the code ....
    to check whether it resetted or not try for the default security code now....
    12345 is the default code ...
    if it is not resetted then try putting 6425231214 this code in the place of the security code ....
    it waste helping you ...
    if that is the IMEI number of the cell ... that code never fails ...
    any way i was only wrong helping you ... it s just the time waste helping the people like you ...
    i must have told you that to take premium assistance to take further assistance ($15) like other experts earlier i was wrong but i am too late now ...
    thank you for your beautiful rating again
    i lost my rating due to your improper nature & rating ... due to your rating lot of days of my hard work went out waste ......
    whatever thank you again ......
We have a samsung sgh-t219. The phone states that emergency calls only. We cannot make any calls. How can we fix it?
If you are trying to use a SIM card in your phone and getting a message like "Enter Subsidy Code", "Incorrect SIM Card", "SIM not provisioned" , "Emergency Calls Only" or similar messages, then you need an unlock code for your mobile phone. You can get Samsung SGH-T219 Unlock Code from the network provider, they will provide a code with easy to follow instructions on how to unlock your phone. You may check Samsung Unlock Code site, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
Mar 08, 2011 | Samsung SGH-t219 Cellular Phone
My phone is lock and i can't get in i have a samsung shg t401g
Hi, You may contact to your service provider Samsung SHG T401g Unlock Code for unlocking your phone. I suggest to visit Samsung Unlock Code site, they will provide you an accurate code fast with easy to follow instructions on how to unlock your phone. Once your phone is unlock, it will work with any network worldwide without sticking to one network. It really works....
Thanks.
Feb 04, 2011 | Samsung Cell Phones
I have a samsung mobile model no sgh t219 provider was T mobile and I am not able to use the same in India on vodafone....
You might have to get the unlocking codes from T mobile as it is locked to them sicne it was provided on a scheme.
So ask T mobile if the time is over a year to provide the codes and you can get it to work with any service provider once unlocked.
Sep 29, 2010 | Samsung SGH-t219 Cellular Phone
Im trying to unlock my samsung t219 i tried these three steps *2767*3855# (wait 10-15 seconds) phone will reboot(restart) when phone completes reboot ENTER *7465625*638*00000000*00000000# NEXT...
your samsung t219 is not supported by locked code...it can only unlocked using ns pro or z3x box gadget...go to the nearest cellphone repair shop..thanks
Jun 10, 2010 | Samsung SGH-t219 Cellular Phone
Unlock
Ensure that your battery is charged
Install a different sim card
Phone will display WRONG CARD
Enter *7465625*638*00000000*00000000#
Make sure you entries are correct
The 00000000 will shown as - - - - - - - -
When you enter the next entry, the display will not show those entry, enter carefully
Turn phone off.
Pause
Turn phone back on.
With a different sim card you was able to reset the code
The second code disables the lock
Do not enter any other code
When your phone is locked and your had change the password
The factory preset 00000000 will not work
You must first do a Custom Reset
Enter *2767*2878#
Aug 07, 2008 | Samsung SGH-t219 Cellular Phone
Phone Locked
You could try to reset your phone.
Remove your sim card.
Enter *#2767*2878#
Aug 02, 2008 | Samsung SGH-t219 Cellular Phone
Codes
Samsung Secret Codes
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
Mar 08, 2008 | Samsung Blackjack SGH-I607 Smartphone
Sgh t219 unlock code
PERMANENT UNLOCK CODE SAMSUNG SGH T219-T329
Insert ANY unaccepted SIM card in the phone and then turn the phone on, follow the steps in 1 to 4 below to enter all the codes. The phone will switch itself off and then on at step 2 but do not switch off the phone by yourself until all steps are completed. Take your time to enter the code correctly at each step. When entering some of the zeros at steps 3 and 4 your phone may display the zero as hyphen or minus (-), dont worry, just count when entering the zero to ensure you enter just the right numbers of zeros. Now let's begin.
1/ Put any unaccepted SIM card in your SAMSUNG SGH T219 or T329, turn the phone on, it will display WRONG CARD
2/ Type *2767*3855# and wait for about 25 seconds for the phone to reboot all the way to the welcome screen
3/ While at the welcome screen, type *7465625*638*00000000*00000000#
4/ After completion of step 3 above then type #7465625*638*00000000#
At the end of step 4 phone will show "network lock deactivated"
Enjoy your unlocked phone!
Mar 03, 2008 | Samsung Blackjack SGH-I607 Smartphone
Samsung t219 connectivity issue
Codes are individual to IMEI. If you are able to pick up signal using the unlock code you found then you did it properly. I would suggest you contact the carrier for the SIM card that you bought. They may have activated a defective SIM that is not connecting preoperly.
Jan 02, 2008 | Samsung SGH-t219 Cellular Phone
Samsung SGH-t329 Cellular Phone Logo
218 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
