1/2 of LCD screen not working - Televison & Video
    Problem Solver:
  • 10 Answers
Unfortunately you have one of two issues.
The first is the lcd controller has failed due to age or a manufacturing fault, which means the screen is essentially dead.
The second is that the screen has taken a knock and has cracked, either way it's essentially dead.
Time for a new lcd tv
Posted on Jul 02, 2008
TV no longer power's on. What problem is causing this condition?
If the TV AND the DVD player are not powering on, then it sounds like the problem is at the receptacle or power strip, where the TV and the DVD player are plugged in. Make sure the receptacle or power strip is working. Plug something else in, a lamp, a radio, anything, and see if it works. If it doesn't then the power strip is off or not working or the wall receptacle is not working.
May 25, 2014 | Coby TVDVD2050 20 in. TV/DVD Combo
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My pc is showing a white screen when iys on
Sidekick lx screen went blank isnt working..
You can try to reseat the lcd cable and make sure it is tight. It that fails then you will need to replace the LCD screen
Here are instructions for replacing the Sidekick LX screen: How to replace the Sidekick LX LCD Screen
and here is a link to the LCD screen son ebay.
Sidekick LX LCD Screens
Oct 05, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Lcd light
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD screen is very easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jul 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Can I install an LCD screen ?
TRY IT IT SHOULD BE THE SAME CONNECTION IT NEVER HURTS TO TRY ULL GET ONE PLAYING
Jun 27, 2009 | Insignia Pilot MP3 Player
Broken Screen
most are. you need to open the lcd and get the model number from the back of the lcd itself. you will need manufacturer, model number and revision number.
if the glass is not cracked, you may simply need a new backlight.
Nov 17, 2008 | LG 42LC2D 42 in. LCD HDTV
LCD lights up, but is blank when i open the flip
yeah that is possible. make sure you know what you are doing and don't damage the working LCD screen it might just be easier to replace the whole cuircuit board that the LCD screen is on.
Feb 21, 2007 | Motorola Mobility V265
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
