Had ac for a a month, worked fine unitll now, now its spitting out a lot of water, to much to even keep on. when we installed it, the instructions said to put wood down on window seal to level it out. take the boards out?
It needs to be installed sloping slightly outside. It is not meant to be level. Use boards or whatever to do this. If this doesn't solve the problem the drain channel is plugged. Take off the outer case and look at the bottom there should be some kind of channel from in front to the back. Use a turkey baster or something to flush it. The back may be fairly deep to hold some water. Don't drill a hole. Some units keep some water in the back so the outside fan can throw it through the condensor to help cool it.
