Question about Microsoft Xbox 360 Console
360 wont go on
What can i do, my 360 doesnt go on, no matter what i do, i have the brick with the orange light on, but the 360 just doesn't go on, and it was fine last night
  • Edward Stewart
    Edward Stewart May 11, 2010
    Has the light on the power brick turned red?
    Basically after leaving the power brick unplugged for several MINUTES (not seconds) give it a good 15 to 20 minutes and disconnecting it from the xbox when you plug it in it should be red meaning it is not running any power through it.
    When you connect the xbox it should turn orange indicating the xbox is drawing standby power
    IF this is the case what colour does the light turn on the power brick when you press the power button on the console. Any lights or sounds made by the console?
    Or do you get absolutely no response?
    I need as detailed answers as possible.
  • Edward Stewart
    When you press the power button does the light on the brick change colour?
    Try unplugging everything (including the brick from the console the hard drive the av cable and the brick from the wall)
    Leave unplugged for a few minutes
    Try reconnecting everything but the Hard drive if you have one.
    What happens? any cahnge in lights on the console or the power brick
It did not work
Posted on Jul 05, 2008
Why wont my xbox 360 stayed powered on the light on the power brick is orange what does that mean
You might need a new charging brick. Make sure you get the right one, as many are different. The "Brick" is actually the Ac/Dc converter. The reason the PS3's don't have them, is because they are built INSIDE. I wish Xbox would figure that out. ^^ Good luck.
Jul 14, 2014 | Microsoft Xbox 360 Console
Xbox 360 slim wont turn on but it beeps and lights up
there is a short somewere In the system and it is in protect mode and will not turn on so that the console does not get harmed anymore than it already is. the best solution for this is to send it in to Microsoft and get this problem fixed
Jul 11, 2013 | Microsoft Xbox 360 Slim Black Console
When i plug the xbox up the light on the plug adaptot turns orange and the xbox wont turn on
This is usually caused by the power brick over-heating. Try cleaning out the vents on the power brick. There are little holes on the ends and overtime they become clogged with dust and lint. If that doesn't work then you'll have to replace the power brick.
Jan 29, 2012 | Microsoft Xbox 360 Hard Drive (120GB)
Orange light on brick plug it into my xbox and light goes red and it wont switch on
the 360 has a power fault usually it is drwaing toomuch power for the relay in the brick to switch over, try removing the hdd and any wired controllers you may have in it and see if it will turn on
Jul 01, 2011 | Microsoft Xbox 360 Console
My x-box 360 power brick light is always orange and no matter what i do the console wont work any help???
Umm if you have sound then your yellow av cord must be faualty (The yellow av cord is the one that produces the pictures onto the screen) But if you have no sound and the power brick and xbox is humming away nicely then i recomend taking it to a repairer to try and get it fixed.=]
Nov 06, 2010 | Microsoft Xbox 360 Console
Xbox 360 elite has suddenly stopped working and doesnt light up
check you have a light on the power Brick. Usually Orange On Standby.
Push power On Button, should turn green.
No Light At All Check Plugs Fuse.
Orange light On, but not turning on, or going to Green, power Up.
Suspect Faulty Power Supply Unit, Or Motherboard Fault.
Mike @ Compurepair.
Mar 25, 2010 | Microsoft Xbox 360 Console
Plugged it up and wont come on only gettin a orange light c_rodwell@yahoo.com
if your power brick light is orange u need a new power brick 4 your xbox 360
Dec 22, 2009 | Microsoft Xbox 360 Console
My powerbrick lightis orange but my xbox360 wont turn on
If the light on the power brick stays orange after turning the console on it means the brick is not properly functioning. You can attempt to clean the power brick with a can of air. Also make sure it has ventilation and is not sitting on carpet. This can cause the power brick itself to overheat and cause issues with it and the console itself. Also make sure your 360 is not plugger into a surge suppressor as this can cause issue due to double protection.
If possible, test the power brick on a different console, and test the console on a different power brick. This will narrow down your problem area.
Dec 22, 2009 | Microsoft Xbox 360 Pro System Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
Power brick problem and power light too
I've made a post here, so you can
<a href="http://3redlightfix-xbox360repairguide.blogspot.com/">Easily Fix Your Console</a><br>
Hope that helps
Feb 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
