Question about Microwave Ovens
Microwave runs but will not heat(unit is approx. 5yrs old)
  • 2 more comments
  • claytjani Jul 03, 2008
    microwave is Kenmore Elite Mod#721.63684300....every thing works,but no heat....can hear clicking noise behind control panel every 10 sec.
    getting F-9 error code at times
    is it worthwhile to repair this microwave or better to buy a new one($500 new)?
    approx cost to replace magnatron???
  • 2,071 Answers
F-9 error code- means the problem in the door lock circuit,lost of door lock circuit protection or door latch supervisory ....
solution: check wiring and test operation of door lock switch,check ,replace clock assembly (also called the ERC) or if relay used then replace power relay board.
Posted on Jul 03, 2008
  • LORETO LACARON
    LORETO LACARON Jul 03, 2008
    ERC -means electronic range control /clock failures of this part can affect the heating process.Below the site sales parts on line and more information F-9 code error http://www.repairclinic.com/0078.asp#Kit...
    http://fixitnow.com/oven-repair-faq
    http://www.repairclinic.com/SmartSearch/...
  • 2,335 Answers
If your microwave is less then 5 years old, the magnetron might be still cover under manufaturers warranty. F9 error code is related to magnetron failure and will need to be replace.
    Sergeant:
    Champion:
  • 417 Answers
The heating mechanism is worn out
    Genius:
  • 1,142 Answers
If it is not heating then the magnatron needs to be replaced.
    Master:
  • 726 Answers
Ekse is exactly right time to by a new one
  • chris07551 Jul 03, 2008
    also i googled it 4 u and found this info that the heating part has failed can cost up to 120 dollars to be repaired cheaper to by a new micowave
    and also the heating meganizim is also dear i got qouated 80 dollars and that was 4 a chepo micowave
  • Microwave Ovens Master
  • 13,433 Answers
You will have to take the microwave to repair or buy a new one.
The unit / part that does the heating has failed.
Replacement parts may be available if you are interested in repairing it yourself.
    Sergeant:
    Champion:
  • 230 Answers
The problem may be with your thermostat check that ,and repair it
Kitchenaid Superba KEMS307D Microwave buzzes, looks like it works, but doesn't heat. Full normal display, tray rotates, but fan doesn't sound normal.
Most likely causes - shorted high voltage rectifier, or failed high voltage transformer, or shorted high voltage capacitor, or shorted magnetron. If an odor accompanied the failure, high voltage rectifier or transformer most likely. All of these components operate on 4000 v, or more - with enough current to kill you. Make sure the unit is unplugged, and the high voltage capacitor is fully discharged before testing.
Apr 10, 2014 | KitchenAid Microwave Ovens
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
Runs but won't heat
if everything else is working but the heating portion then your problem is most likely going to be either a bad magnetron on unit or a thermal cutoff on the magnetron... the way to access the magnetron is unplug unit and remove touch pad.. located behind touchpad you will see a square device approx. 3 inches by 3 inches and there should be a limit switch attached to the unit... remove wires and test limit switch using a meter. it should be closed and give contuinity through it... if not it is bad.. if it does then most likely the magnetron has failed ...good luck to you ..the magnetron is general a expensive part compared to the prices of the unit...
Jan 19, 2011 | Hotpoint RVM1435 Microwave Oven
Microwave run but dont heat
The running sound is only the fan. The heat comes from a magnetron which is the primary part of every microwave, Sounds like the magnetron is dead. If it's a newer unit (1 to 3 years old) it should be covered under a warranty. Contact the manufacturer for repair or replacement.
Mar 24, 2010 | Microwave Ovens
Ge over the renge microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdhjd
Feb 13, 2010 | GE JVM2070 Microwave Oven
Panasonic Microwave NNSD277B 5yrs old makes noise after 20sec on (bUzzing and popping)and internal light flashes. Should be replaced or fixed ? what could be the problem?
You should have no arcing within the unit. Assuming you have adequate food/water in the cavity, it should not arc. You NEVER run the unit without something to be heated in it!!!
You might check the stirrer fan which is often in the roof of the unit to see if contamination might be in the area causing arcing. The electric fields in th area are very high and arcs can jump.
If the insulating window is charred or has charred grease, it should bbe replaced.
Dec 26, 2009 | Panasonic Microwave Ovens
GE JVM1440WH01 Will not heat, everything else works. This unit is 6 years old and just stopped heating. The carosel turns, fans work, the timer counts down and lights come on when you start cooking or open...
It could be a number of things, Burnt connections between the magnetron, Capacitor, Diode and transformer, Heater connections loose or burnt, Transformer, Capacitor Diode or Magnetron US. You need to strip it and find out if you are getting about 2000volts to the Mag, Are you getting approx 5volts across the heater terminals?? NOTE that the 2000 Volts can remain in the cap indefinitely and the voltage is LETHAL. IT WILL KILL YOU if you don`t take precautions. Ian
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Jul 29, 2008 | Kenmore 62622 Microwave Oven
Microwave nooven does t heat new,model jvm15400dm2cc
hi,
if the unit will not heat in any mode, it is likely a magnetron and/or H.V. transformer problem. if the unit is less than 5yrs old some manufacturers have 2-5yr warranty on these parts, find your proof of purchase and call the manufacturer. if it’s more than 5yrs old, get a new microwave, the repair will cost more than a new unit.
Mar 30, 2008 | Microwave Ovens
Oven runs but does not heat
This is going to be either the high-voltage transformer, the magnetron, or the high-voltage diode. Magnetrons are the mosty common failure in these, and there is a campaign underway to replace "underperforming" magnetrons. To see if yours is one of these, visit: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf
Apr 05, 2007 | GE JE1640WA/GA Microwave Oven
Microwave Ovens Logo
124 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
