Question about Sharp AR-M160 Laser Printer
L 6 On the screen it gives the below message L then 6
  • 1 more comment
  • Anonymous Jul 06, 2008
    Display blinkiing L then 6. We blew out dust, replaced cartridge, but nothing changed
  • dbc0962 Dec 02, 2008
    Copier stopped working then started flashing L, then 6. Nothing in the manual about this code. Repairman not available. Help!
  • gig8 Apr 20, 2009
    This procedure does not help, where ist the polygon motor seated?
  • 32 Answers
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Posted on Mar 25, 2009
How to delete sent and received messages
Hi, Follow the below steps to do it..
  • From the home screen, tap the Messaging icon
  • 2.To delete an entire message thread, tap and hold on the thread
  • 3.Tap the Trash Can icon
  • 4.Tap Delete
  • 5.To delete a single message, tap the thread the message is in
  • 6.Tap and hold on the message you would like to delete
  • 7.Tap Delete
  • 8.Tap Delete
Apr 04, 2016 | Alcatel OneTouch PIXI3 4.5 with 4GB Memory...
What is the default admin password?
There isn't one! If you need to reset it do the following. Turn off your Epson WF-3640 using the power button.
After it's off Press and hold the " # " button on the number pad of the printer and then while holding down the "#" button press and hold the "Power" button at the same time. This will turn on the printer and you'll see a list of items on the LCD screen. Use the number "3" or "6" to move and highlight the "Password Initialization" option. Once highlighted hit the "Color" start button on the pad (below the Stop button). to initialize password reset. Once that is done a confirmation message will show up on the screen to confirm you want a password reset. select the "Stop" button on the panel to confirm it as "Yes". This will then give you a confirmation message that the password has been reinitialized. Once you get the confirmation message just turn off the printer using the power button. This will remove any password set on the printer and will give you access to all ADmin options within the printer.
Hope it helps you!
Dec 29, 2015 | Epson WorkForce WF-3640 Wireless Color...
Give me gprs setting of gu285
Select the phone settings you require from the list below and send an SMS to 4252(SMS is free) containing the corresponding order code. Shortly after you will receive the settings on your phone.
WAP
Order code Setting Type
3103
Contract (over GPRS
3108
Ready To Go (over GPRS)
Installation instruction
1.You will receive a WAP configuration message for your phone.
2.The display shows: "[1] Message".
3.Press "View" and "Install".
4.Enter the PIN code 1234 and press "OK".
5.Press the "End call" button to return to the main screen.
6.Your phone has been configured.
7.Note: The settings will be rejected if the profile list is full.
8.To delete an existing setting, you need to perform a master reset of the phone.
Kindly restart your mobile once the installation is complete.
Regards
Jun 27, 2011 | Cell Phones
2008 Land Cruiser
pls send to me toyota landcruiser 2008 drive belt diagram
Jul 21, 2010 | 2008 Toyota Land Cruiser
I have an LT Series Gateway Netbook. I am trying to connect to a Sony VPL-AW15. I am using a Sony STR-K7000 A/V receiver. The projector is giving the error message "Frequency out of range". I have...
HEy try changing the refresh rate
1. Right click on a empty space on the desktop and click on Screen Resolution. (See screenshot below)
2. Select the monitor Display you want to change the screen refresh rate for. (See screenshot below step 3)
NOTE: You will only be able to select a different display if you have more than one monitor connected.
3. Click on the Advanced settings link. (See screenshot below)
4. To Change Only the Screen Refresh Rate -
A) Click on the Monitor tab. (See screenshot below step 4C)
B) Select an available Screen refesh rate from the drop down menu.
WARNING: It is recommended to leave the Hide modes that this monitor cannot display box checked to prevent possible damage to your monitor.
C) Click on OK. 143d1229784117t-screen-refresh-rate-display-settings-monitor_settings.jpg
D) Go to step 6.
5. To Select from a List of All Display Modes -
A) Click on the Adapter tab, and on the List All Modes button. (See screenshot below) 7331d1238960189t-screen-refresh-rate-display-settings-adapter1.jpg
B) Select the display mode with the screen resolution, color depth, and screen refresh rate that you want to use, and click on OK. (See screenshot below)
NOTE: It is recommended to use a native screen resolution with a True Color (32-bit) color depth. 7332d1238960189t-screen-refresh-rate-display-settings-adapter2.jpg
C) Click on OK. (See screenshot below step 5A)
6. Click on Yes to confirm the screen refresh rate change. (See screenshot below)
7. Click on OK. (See screenshot below step 3)
Apr 28, 2010 | Lenovo IdeaPad S10e Netbook
Can't multimedia message from sci phone how do i set up for at&t
must be peformed exactly.
MMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
Apr 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Motorokr touch screen malfunction
choose that master reset on setting wizard,,
dont do again anything with that screen calibaration,,,
Dec 20, 2008 | Motorola Mobility ROKR E6 Smartphone
Change font size
I'll trade you - mine is too small. I can change it every time I write a message but I want to change the default. To change it for an individual message, press the right soft key, and use option 6 - just below the screen, you have to arrow down to it.
May 20, 2008 | Samsung SCH-u340 Cellular Phone
Samsung Blackjack
You need to go to folders and switch to your inbox. There are 5 folders...you are probably in deleted items or sent items.
Sep 27, 2007 | Samsung Blackjack SGH-I607 Smartphone
Sharp AR-M160 Laser Printer Logo
411 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
