Question about Cybernet Systems CyberPower 625AVR (cp625avr) UPS System
Shutting down computer
My Cyber Power 625AVR doesn't stay on long enough when a power failure hits for me to shut down the computer. It just goes black and shuts down in the middle of what I am doing.
  • Neonan Jul 03, 2008
    Thank you Worldvet, you help is appreciated. We have an Ace Hardware here so will check this out. I also did a little research and I guess I need a Power Panel Software CD that installs the option to save things before the battery shuts down.
    I had done a system reinstall quite a while back and somehow forgot that I needed the CD that came with battery when I bought it. Sadly, the CD is nowhere to be found.
    Thank you again for your offer of help.
    Guru:
  • 859 Answers
You need a new battery. A battery store such as Batteries Plus can help you. Many Ace Hardware stores will order one for you and in fact, Radio Shack has the most common battery types in store or can get it for you. If you go through Cyber Power you will pay the highest price.
Hope this helped you.
Regards,
Worldvet
Please don't forget to rate all our solutions on Fix Ya.
Posted on Jul 03, 2008
System runs from about 3 to 15 secs then shuts down. That doesn't give me enough time to do anything in the BIOS setup when pressing F2. Then the system refuses to start (by pressing the power button)...
Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged. The computer should stay on even without an operating system or hard drive installed.
Jun 24, 2011 | Dell Precision Workstation T5400 Quad Core...
WINDOWS NOT SHUTTING DOWN COMPLETELY
dude i think its the BIOS prob try reseting the bios u can do so by removing the maotherboard battary for one min aand then replacing it this will surely rester the bios.this should it
Feb 03, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
You will need to enable the Advance power management in Bios and on windows..
Try to see in the bios the advance setting for APM.
Some motherboard you have to enable this.
Other its simply on windows.
After the installation of windows
Go >Right click desktop>properties>then select screen saver tab>below click power>
Then click APM tab
enable and restart
May be this can solve this issues.
Or else I would advice to change the power supply and see.
Regards
uttam
Feb 03, 2010 | Computers & Internet
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
TV shutting down
Probable main power supply failure. In all modern sets, there will be two power supplies; one that keeps the set enough alive to respond to the remote and a second one that does the 'heavy lifting' supplying several regulated voltages for different subsystems. This latter one has failed.
If you can locate the main supply board, it may be fairly easy to remove to send off to the factory for repair.
Dec 04, 2008 | Televison & Video
RCA 27V530T Powers up and plays perfect for about 5 min then shuts off
look for cold solder joints on primary side of power supply
Jul 01, 2008 | RCA 27V530T 27" TV
Cybernet Systems CyberPower 625AVR (cp625avr) UPS System Logo
130 people viewed this question
Top Cybernet Systems Computers & Internet Experts
David Payne
David Payne
Are you a Cybernet Systems Computer and Internet Expert? Answer questions, earn points and help others
