Question about Samsung HLR5067WX 50" Rear Projection HDTV
NO PICTURE The buld looks good. I can hear a click as if trying to start the bulb, but still no picture. I was told that some dust may have gotten into it. There does not look like anything for dust to get into. How can I test the buld and the board starting the bulb? Samsung HLR5067W-Picture scrambled bad then goes out.Have sound ,also have a DVD player hooked up, plays fine,go to TV mode have sound,no picture.Replaced Lamp.Same Problem.....
  • 5 more comments
  • kbhaught Jul 03, 2008
    Sometimes when I hit the power button some lights will blink but not all at once so I don't think it's the bulb. It somethimes sounds like it's trying to turn on but gives up. What can I do?
  • Anonymous Jul 21, 2008
    No matter what button I hit on the TV remote, it indicates TIMER on the 1 inch round button on the front. No picture at all anymore, though I started out experiencing a locked up or scrambled picture, which would periodically unlock as though things would be fine. Then, it would lock up again. Now I've got nothing, with blinking Timer light everytime I try something new.
  • Anonymous Jul 25, 2008
    good sound no picture? Red light blinking on front of tv
  • plcarlos10 Jan 14, 2009
    So, has anyone figured out what to do with this issue?
  • 40040x Feb 11, 2009
    When I turn it on I can hear something power up, the lamp indicator on the front blinks for about 10 seconds, the the lamp indicator then turns off and the Standby/Temp indicator light then will blink for about five seconds. Lastly, the Standby/Temp indicator light stays on and the tv "powers down."
    Worked fine one night and the next day this occurred.
  • suzyqjet Feb 27, 2009
    I have the same problem, Power up and lamp led flashes for 15 or so seconds, then it goes to standby and the bulbs shuts off. No picture or sound. Thanks
  • Anonymous Apr 18, 2009
    Samsung HLR5067WX/XAA
    All three tights were on. I called a service company who no longer work in are. the said that it ment that it needed a new lamp. I replaced with lamp and new housing.$130.00
    Still does not work. The lamp light is now on alone.
    Can any one help?
The only solution I could find was to put the Samsung in the Repair Shop!
When I get an answer to the problem and cost of repairs I will post it and hopefully
It will help someone else with this problem fix their set just for the cost of parts.
Yea I'm gonna take one for the team!
Posted on Jul 04, 2008
How do u change bulds an where they at
bulbs do not get changed as it has picture tubes--sounds like a convergence problem--replace the two STK-392-110 or 150 chips it has.
Jun 14, 2012 | Hitachi 51F510 51" Rear Projection...
I have a Toshiba model 65HM167. The bulb exploded about 6 months ago so I replaced it and everything worked fine until now. Now the TV will power on and I will get sound but no picture. The yellow light...
Unfortunately lamps go bad without the visible state of being bad. I don't know who or where you bought the lamp from but I order all my lamps through dlplamps.com
The clicking sound you hear is the lamp inverter igniteing the lamp but the lamp is bad.
Nov 29, 2010 | Toshiba 65HM167 65" Projection Television
My kp 53s65 picture seems to be darker now than when i bought it. is this normal in a dlp tv ? someone told me to change the buld but i was not sure if i should.
KP53S65 is a rear projection Sony several years old--It is not a DLP and does not have a bulb--it has three picture tubes---if the set has not been serviced in a long time here is what you can do to try to improve it:
1.) Unplug set
2.) Remove back cover
3.) You will see 3 black lens (one for each tube)
4.) With a paper towel (spray glass cleaner on it) clean the dust from the three lens---if they have not been cleaned in a long time and have dust on them the picture will be darker and less distinct.
5.) Replace back cover and plug set in to see if this has helped----I have seen some where there was so much dust on the lens that it looked 50% better after just cleaning the lens--depending on area you live in--should be cleaned once a year.
I do this here for free so if this has helped you please take a minute to give me a vote here.
SD TECH
Sep 19, 2009 | Sony KP-53S65 53" Rear Projection...
My Toshiba 52HM84 blows bulbs
Ensure that you don't handle the bulb with bare fingers. wipe the bulb with meths and hold the buld with a lint free cloth when you're putting it in. If it's still blowing it's probably over heating so check the fan
Aug 22, 2009 | Toshiba 56HM66 56" Projection HDTV
The picture (screen) is fading.
You Need A new bulb, its going to pop any minute, you will literally hear a loud pop like smashing a lightbulb. Order one now online, cause it really sucks when you have to wait a week for a new bulb. There easy to install yourself, very simple. Calling a tv man would be a waste. You can fond a bulb online for around 90 to 150, anything over 150 is a rip off, look somewhere else.
Dec 27, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony Kp 51ws510
Sounds like convergance ic problem to me
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Nov 21, 2007 | Mitsubishi WD-52525 52" Rear Projection...
How do I test the bulb?
Pull the bulb housing out of the side of the unit and look into the bulb, you will see that it has shattered into pieces inside. Right or left side of unit is an access door with a few screws, loosen and remove the housing holding the bulb. matelectronics carries bulbs.
Jul 03, 2007 | Samsung HLN617W 61" Rear Projection HDTV
NO PICTURE
The bulb is bad, replace it, you cannot test the bulb. You can test the inverter circuit, but you will need a service manual and the knowledge on how to work on and trouble shoot solid state printed circuit boards. Good Luck
Samsung HLR5067WX 50" Rear Projection HDTV Logo
120 people viewed this question
Henry  Thomas
Henry Thomas
