You are having problem with the roller so remove it out and clean properly and insert it once again this may solve your problem .....because of your roller is not functioning well your paper is moving towards right
if your problem is still not solved try this reset your Canon printer, turn the printer off with the power button. Then disconnect the data cable from the printer. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable. Then turn the printer back on.
unplugging for 10 min is overkill, :30 sec will do, any juice in chips will be drained
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows)
Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
When the printer pulls a - spacer.gifer Cleaning is completed.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
Note: The following mWhen the printer pulls a - win_roller_clean_ip1500_6.jpgpaper is fed and ejected.
Sorry pictures didn't go through.
Open the printer properties.
Remove all sheets of paper from the auto sheet feeder.
Confirm the following message, and click 'OK'.
Note:
until this operation has finished.After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.Click 'OK'.
Roller Cleaning is completed.
Either the paper might too much thin or the wheel from which the printer pulls on the left side of the sheet might be damaged or not working correctly or may be there is some obstacles
Could you please confirm the platform u r working on(Mac or windows) and also r u referring toward duplex printing??
There is a broken gear on the left side, specifically the paper feeding gear, take this unit to a local service center as the gears are not user replaceable and you cant purchase them from local shops... contact the printer manufacturer to get a local service center CANON
Use a better qouality of paper try that or try to setup allignment goodluck
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
