Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Canon eos 400d
Hi i have a canon eos 400d and last week i bought tamron lens af70-300mm and managed to take a couple of shots. few days later when i used my camera with the canon lens it originally came with it came up with err99 message, i turned it on and off several times, took battery out and cleaned the lens it worked for a bit then the message returned. now i also found that whilst it is better to take picture inside when i take picture of outside from the inside the picture turns out to be very bright (almost white) and if i take picture outside it wont take it and instead it comes up with err99 message again. do you think its faulty with the camera ( i only bought it in Jan 2008)
thanks
    Problem Solver:
  • 15 Answers
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Posted on Aug 31, 2008
Lens filter choice for photographing solar eclipse 20.03.15 south UK
A bit late but try here for solar filters www.wexphotographic.com
Mar 12, 2015 | Canon EOS 600D Rebel T3i Digital Camera
Can i use a Cullmann C28 flash with Canon Eos 400d?
Doubtful. I tried similar with a different brand of flash designed for a 35mm. It worked for about 20 shots then the diodes fried. I've since bought a used Speedlight for my 400D and it works great.
Aug 19, 2014 | Cullmann Cameras
Hi, I bought a CANON FD - 28 mm f 2.8 WIDE ANGLE LENS for my OH's eos 400D, he says it doesnt fit, its too small. Is there an adapter or anything or should I just look for the right one? Many thanks
Canon FD lenses date back to before the mid 1980's. They use a totally different mounting system to the later EOS mount which was a redesign to suit the needs of auto-focussing.
Unfortunately they are chalk and cheese: you cannot realistically fit an FD lens to an EOS camera.
Your fix is to sell the lens and to buy one with an EOS mount.
Jul 20, 2011 | Canon FD 28mm f/2.8 Wide Angle Lens
My Canon 400D camera keeps coming up with error 99 I have cleaned the contacts on both my camera and my Tamron 28-200 lens.At first i thought it was my camera but I tried it with another lens and it...
Hi turn on the camera with the lens on set to tv and a iris of f22 and use the stopdown button if the lens stops down the lens is ok if not the lens is faulty may need a intuper replaced
Jan 11, 2010 | Tamron 28-200mm F3.8-5.6 for EOS
Need Help, the auto focus of my canon 400D won't work.(I can still shot with manual focus)
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I want purchase a zoom lens 55-250,70-300,75-300 for my Canon EOS 400D camera what is the price range?
If you are talking about canon only (not sigma/ tamron etc) lenses then there are many different variations of the above lenses ranging from a few hundred to over a thousand UK pounds ( I dont know your currency/country) If you are looking at the budget market then the best value of the 3 mentioned id the 55-250 by canon which has good optical quality and built in IS (Image stabilistaion) and is remarkable value for a CANON branded lens
http://www.photozone.de/canon-eos/194-canon-ef-s-55-250mm-f4-56-is-test-report--review
Other option in the price range would be the 75-300 mk III but it is non IS but does give you a longer reach.
Mar 25, 2009 | Canon EOS 400D Digital Camera
Images shoe up red
sounds like you might have an overheating CCD. Turn off the camera for couple of hours and when you try again if this happens again, return it to the store you got it from for warrenty repairs.
Jan 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Sep 10, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
141 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
