Home | Black & Decker | TRO360 Toast-R-Oven Toaster Oven with Con... | Toaster does not work!!!
Black & Decker TRO360 Toast-R-Oven Toaster Oven with Convection Cooking
Problem for Black & Decker TRO360 Toast-R-Oven Toaster Oven with...
By robflone on Jul 02, 2008
the top burner does not come on when trying to toast, just the bottum burner. when using the broil feature on the unit , only the bottum burner comes on. I checked the unit & don"t see any visable problems.
Same Problem
Jul 25, 2008
-   I have the same problem with a similar model, TRO1000-4000 series. I took it apart and checked the resistance of the top elements (there are two which I believe are in series) and they seems OK at about 25 ohms (similar resistance to the bottom two filaments). 120VAC seemed to be getting to the elements when the unit was on. So, I am stumped on this one. There is a complex set of contacts and connections on this oven (right side under cover) which are not easy to decipher. In addition, the unit is a bit difficult to disassemble and get back together (although it was easy after the third time). I'm afraid these ovens are not made too well. They seem to last 5-10 years - short in my book. I've had older toaster ovens for 20 years. -   klezwoolfe
Best Solution
posted on Jul 27, 2008
Very Helpful)
klezwoolfe
Rank: Apprentice
Rating: 95%, 7 votes
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Black & Decker TRO360
Questions and Unsolved Problems for Black & Decker TRO360
Do you recommend Black & Decker TRO360 Toast-R-Oven Toaster Oven with Convection Cooking?
Answer
Answer
I have the same problem on TRO350 and this is my third Black and Decker in 3 years! I have spend... (More)
Answer
Same as above. If you need any more details please let me know.
Answer
the off/on switch will stick in the "on" position.
Answer
the toaster switch on the black and decker toaster oven does not connect. the bake and broil part... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker TRO360...:
Top Toaster Oven Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Toaster Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
