Question about Gaggenau EB 270/271 Electric Single Oven
Gaggenau eb 270
How do I remove the ovendoor of a eb270 to renew the cover of the display ?
    Problem Solver:
  • 12 Answers
No you don't need to remove the oven door to change the cover of the display. You have to remove the whole unit out and remove the top lid. Don't forget to switch off the circuit breaker before doing this and be careful this unit is heavy.
Posted on Sep 01, 2008
Gagenau eb270 fuse location
I do not think there is a master fuse like on US built ovens. Power goes directly to the controls
Jun 06, 2014 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
May 26, 2012 | Ovens
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau Wall Convection Oven EB 270 installation instrutions and electrical hook up.
http://www.gaggenau.com/US_en/service.do
you can download installations and user manuals from this site. You'd probably be better putting the full Enr (model) number in the search.
Click where it says 'All manuals available for download' this will open a window where you type in the model. You then get a long list of manual, I presume you want it in english, so pick the one that had EN in the first column and II (installation instructions) in the next column.
Hope the is what you're looking for, all the best.
Jul 05, 2010 | Gaggenau EB 270/271 Electric Single Oven
I have a Gaggenau 270-271 wall oven. It is showing F 42 on the screen. what does this mean?
Open circuit in the door contact switch even if the door is locked.
If this happened during a clean cycle sometimes if you start another cycle and then switch the selector off after a few seconds the fault will right itself. If this doesn't work then you probable need a new door lock.
Hope this helps
Jun 11, 2010 | Gaggenau EB 270/271 Electric Single Oven
How do i fit the rotary spit for eb270 built in oven
insert the support frame in the 2nd level from bottom - wiggly bit facing outwards and up. inset grilling tray on bottom level to catch fat. Heat oven, then insert end of rotary spit in hole at the back RH corner of oven (slide cover aside) balance front end on wiggly bit, unscrew handle, close door and press rotary spit key (2nd from Left bottom row)
Jan 16, 2010 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Oven
go here
http://www.gaggenau.com/AE_en/Home.do
the customer support
then operation manual
Dec 04, 2007 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB 270/271 Electric Single Oven Logo
247 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
