I have a 46-inch Philips Rear projection TV. Recently, its image has become distorted. I'd like to fix it myself and am pretty handy with electronics, I just don't know what to replace or fix.
For the most part, the image appears distorted due to one color being out of alighment or completely shop. Its almost as if it bows the screen. Its most noticable when watching CNBC or anything that runs a ticker across the bottom of the TV. In the middle of the screen at the bottom, one color rises, giving a double image in the middle of the screen at the bottom. Its also distorted in the upper left and right corners. Everything esle seems O.K. So I can watch the TV for the most part, but the distortion is a little annoying.
Any suggestions of what needs replacing? I'm willing to give it a shot, but need some advice. Thank you in advance. Robert
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Here are some of the most common symptoms and example photos. Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
i have the same problem
i have a doble picture to
My TV also started having the same problem and now when I turn it on the pic starts flickering and then it turns all black no image
