Question about GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC Side by Side Refrigerator
GE frige no defrost
I'm an appliance technician in Wy, but can't seem to find out why a GE fridge keeps frosting up. The heater and limit are good, so I replaced the control board. It frosted up again, so I checked continuity at the control board through the defrost circuit to eliminate wiring issues. I had continuity, so I thought maybe I got a bad board and replaced it again. She just called back and said it's frosting up again. Any ideas??
  • Austin DeBock Jul 22, 2008
    I've used a patch cord to bypass the board, the heater comes on until the limit opens. This proves the heater, the limit, and all the wiring back to the board are good. I went ahead and replaced the board again and now it's frosting up again. I've put in a total of 3 boards, and a new heater for good measure, now and have not resolved the problem, but I don't know why the boards are not going into defrost. From what I understand they count compressor run time and door openings and previous defrost time to determine when to defrost. I don't understand how everything can work except the defrost cycle.
I just fixed the same problem. Here is the solution. It is 2 parts:
First, the doors on these models are defective. They are not insulated so cool air escapes, causing freezer to keep running thus burning out defrost element.
Replace defrost element. Then, drill holes, on the inside of each door, starting at the top and then every 1 foot down, in the center of the door. Buy 2 cans of the spray insulating foarm from your local home depot. Fill inside of door to insulate them. Wipe away any over fill.
This will make it like new again. GE really botch this one up. There was a class action suit for new doors 2 years ago. I missed it and so did your customer.
Posted on Sep 27, 2008
  • 481 Answers
I guess the first thing i would check is to make sure the control board is getting a proper ground. next i would manually put it in defrost (while it is still frosted) and make sure the heater is glowing red hot. other than that i would have to suspect another bad board? let me know how it turns out
Posted on Jul 02, 2008
  • Mike Durland
    Mike Durland Jul 22, 2008
    i have rewired the adaptive control board for a regular fsp defrost timer for a customer before. this might be the best option in this case.
Iv got a fridge freezer frost free hotpoint the freezer is keeping frozen but my frige is warm all the time can u please tell me what the problem could be please.
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jul 05, 2011 | Refrigerators
Fridge works for about 3 weeks then freezer freezes up and fridge stops working i unplug it for 24 hours and it works for another 3 weeks same story??? what do i dooo? it is a ge side by side newer...
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
Apr 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our side by side GE Refrigerator feezer is defrosting and the refridge side is barely cool. The fridge is only three years old. what should I do?
Look at the back wall inside the freezer from the middle down, if you see frost evenly on the back wall then the Defrost system has failed.
Posible fixes, Defrost limiter, Conttrol board bad, Heater Bad, Defrost timer bad.
if you did see the frost you could buy some time by defrosting the evaperator with a hair dryer. (( if you dont know what your doing the please call a appliance repair tech ))
Sep 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My tfx20 fridge, keeps icing up in the freezer. changed timer and defrost thermostat. no help. the fridge does stop on the set times on the timer but never defrosts. Fan is on constantly, no leaks from the...
If the frost builds up on the evaporator coil, sounds like the defrost heater may be out. Check continuity.
If the frost buildup anywhere else - there must be an air leak somwhere. Usually it's the gasket or the ice dispenser flap stuck open.
Vlad,
First Choice Appliance
Jun 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
GE (Mode TBX21ZLG) Frige has water collecting in bottom
if there is definite frost which has some depth to it, you may have a bad defrost timer. look for the timer usually inside kick plate in the front of unit. it'where you clean the condenser coils. with a flat head screwdriver or your finger turn the knob until the unit shuts off. if the fridge doesn't come on in 1/2 hour you have a bad timer motor and buy a defrost timer. if the unit comes on in 20 minutes or so the timer is good and you have to look elseware possibly the condenser coils and fan which are near the bottom clean coils anyway because it's good practice to keep them clean to save energy. the fan either works or it doesn't make sure refridgerator is running to check this. anything else you have to defrost the evaporater in the back wall of freezerthis could take some time but after it's defrosted turn timer to off a see if the heater is red in color if not then with a multi meter with the unit unplugged test across heater for continuity on heater . klixon and hi-temp cut out. good luck. if you are not feeling safe call a repairman
Dec 13, 2008 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Eaton viking fridge model RF1717
hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Oct 07, 2008 | Viking Refrigerators
Fridge not getting cold
This is a frost free frige, so if you see frost, that is the problem. Check the defrost heater, defrost limit and defrost timer/board. You can get by for a while by manually defrosting the fridge. Turn it off, unload the food, and leave the freezer door open for 24-36 hours.
Jul 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator, Model# TFX20JASM
YOU CAN BUY AN INEXPENSIVE THERMOMETER AT WALMART. YOU NEED TO KNOW IF THE FREEZER IS AT 0% . IF IT IS AT O% CHECK TO SEE IF THE FAN IN THE FREEZER WHICH IS CALLED THE EVAPORATOR FAN IS RUNNING. IF NOT THIS IS THE PROBLEM.
IF FREEZER IS NOT MAINTAINING O% AND FAN IS WORKING , CHECK THE LOWER PART OF THE BACK PANEL INSIDE THE FREEZER FOR FROST,IF IT HAS FROST ON THE BACK PANEL IT IS NOT DEFROSTING.IF SO YOU HAVE 3 POSSIBLE PROBLEMS.
CHECK DEFROST TIMER FIRST,MANUALY ADVANCE UNTIL IT CLICKS.IF THE HEATER IS WORKING FROST WILL DISAPEAR IN TEN MINUTES.IF IT DOES CLEAR FROST , FRIGE WILL COME BACK ON WITHIN 30 MINUTES.IF FROST DOES NOT CLEAR , TIMER MOTOR IS BAD,REPLACE.
IF ICE REMAINES YOU HAVE A HEATER OR LIMIT CONTROL PROBLEM.LIMIT CONTROL TURNS HEATER OFF WHEN COILS REACH 40%.LIMIT CONTROL IS A SMALL ROUND BI METAL SWITCH THAT IS CLAMPED TO COOLING COIL.THIS SWITCH HAS TWO WIRES GOING TO IT.
YOU CANNOT BYPASS THIS SWITCH . IT WILL CAUSE HEATER TO OVERHEAT AND MELT YOUR REFRIGERATOR PLASTIC AND RUIN FOOD.
AS YOU CAN SEE REFRIGERATORS ARE COMPLICATED.IF YOU ARE NOT MECHANICAL,ITS BEST TO USE A TECHNICIAN.
Feb 20, 2008 | Refrigerators
GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC Side by Side Refrigerator Logo
154 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
