Question about HP LaserJet 3015 All-In-One Printer
Hp 3015 laserjet scanning in vista
I am having troubole scanning documents using the HP3015 all-in-one. The software is readiris 9.0 and the OS is vista. The scanner is incredibly slow and when the document is scanned, the information on the screen is garbage. It was working perfectly under XP. Is there a fix? Thanks when i scan my form document which is in dotmatrix and alphanumeric, result is perfect in an image like jpeg,btm etc..... but when i sent it to text it does not work properly
  • listless902 Jul 03, 2008
    having the same issues. print and fax work like a charm, but not the scanner. i checked to see if i could use the HP toolbox, but it is no longer supported by HP. i reloaded all my drivers and even tried an older version of Readiris (8) to no avail. any luck on your end yet??
Buy something other than HP which doesn't seem to support anything longer than a year. You bought a cheapo machine, disposable after it breaks which it will about the time warranty runs out.
Posted on Jul 10, 2008
Hp3015 can scan and copy, cannot print original disc cannot recognise the printer is connected when I try to install the driver
go to control panel , sistem and go to administrator divices and update the printer diriver from there
Aug 01, 2010 | HP LaserJet 3015 All-In-One Printer
HP Color Laserjet 2840 will not completely scan legal size docs
have you downloaded the scanfix that is own the HP support site?
May 22, 2009 | HP LaserJet 2840 All-In-One Printer
HP3015 All in One - new toner put in but printing very pale
Try going into the Maintnence Center, should be in Options or Maintanence and running it.
Mar 11, 2009 | HP LaserJet 3015 All-In-One Printer
REadiris won't convert pdf to word
Converting a scanned PDF to Word document requires OCR technology, so that it can extract the text out of an image. Not many PDF converter can make it. You can try the online OCR converter called OCRterminal.com, it can convert scanned PDF to Word, 20 pages for free per month. Hope it helps.
Jan 14, 2009 | HP ScanJet 3500C Flatbed Scanner
HP laserjet 3015
Good Evening MOKSHAKUMAR:
Hope that you are wellJ
Try this first:
Click start, then in search box type printer. A menu should come up that will permit you to troubleshoot your printer.
You did not indicate whether you were getting an error message or not.
Have you tried to uninstall and reinstall the printer and if yes, do you have the same problem each time?
Did you attempt to install new drivers for your HP 3015? This may well be the problem.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP LaserJet 3015 All-In-One Printer
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
HP 3015 prints torn edges and print command prints all the pages at once
if your printer is under waranty then get it to the service center.
Jan 03, 2008 | HP LaserJet 3015 All-In-One Printer
Streaking
Check the scanning glass bar. If you scanned something that had whiteout on it, a lot of times some of the whiteout will get on the glass and will cause streaks in the prints. Clean it with alcohol.
Oct 16, 2006 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3015 All-In-One Printer Logo
162 people viewed this question
Ben Johnson
