Kjb DESA INTERNATIONAL TA100 100K BTU Reddy Heater Heaters Logo
Posted on Dec 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My heater wont stay lit. it shuts down and has a "no ignition" code i cleaned the photo eye, and even shine a light in it after it lights and it seems to be working. if i shine a light in it after it lights then it shuts down and says its out of fuel.
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Feb 20, 2011
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10838095
Points
101584
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Why wont my everdure gas heater stay alight
Some heaters have to be "warmed up" by holding the button down for approx. 30 seconds after it lights. These are ones with whats called a "thermocouple". The thermocouple has to remain a certain temp. or the unit will shut off. If the thermocouple goes bad, it can be replaced
Dusk to Dawn Light Adapter
Might work. Might not. Depending if the eye can sense light and dark from that position. If area is shaded, then the sensor might think it's dark earlier in evening. If the area is dark, then sensor will not do as well, or might stay ON full time.
If the outdoor light shines on nearby surface, the reflected light might cause photo eye to blink on-off throughout night.. or not function as expected.
You can add separate photo eye to any light, and choose location for photo eye.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Add a comment and say what you discover, or for followup wiring question.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 10, 2013 • Home
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
I have a 55,000 btu reddy heater. I adjusted the pump to 3.4psi after replacing the cracked end cover. I also replace the filter and semi-circular foam filter. It spools up, the igniter lights up, and...
You can try repositioning the photo electric eye by slightly bending the holder up or down. I would look at it and make sure there is nothing on the lens and clean with windex dampened terry cloth rag.This is not recommended but you can by-pass the photo electric eye and if it stays running you have found the culprit. You are not clear as to if it even lights, these suggestions are good only if it ignites. Hope this helps you out.
My pro 100 does not light. Igniter heats up and
The photo eye shuts the unit down if the burner does not burn correctly on startup, ie.if the eye does not see light prior to tiiming out. I would say since it is shutting down, it is working OK. While you say there is plenty of fuel, you do not know if there is the correct ratio of air to fuel. The most common problem on these heaters is the mix. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains exactly what you need to do to correct this and where to get the parts to do it. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
2helpful
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Top Kjb Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Kjb Measuring Tool and Sensor Expert? Answer questions, earn points and help others
