My sony dvd is not playing on the tv. all cables are color coded and plugged in correctly
  • 2 more comments
  • lorfly705 Jul 02, 2008
    my sony is mod dvpns57p
    my Sanyo is mod DS27820
    nothing on the screen The numberws on the DVD keep rolling but not picture no sound
    no picture no sound, DVD is rolling, no button on my tv remote or my Dtv remote brings the ddvd to the tv!
    replaced cables from working dvd and still no picture no nothing#$%^&*
  • 689 Answers
Look at the guide below use AV1 or AV2
Match the colors vertically
Click on "INPUT" key a blue screen will appear Choose AV1 or AV2 according the connection you have made at rear panel
Please let us know the outcome so we can try alternate ways to help you.
Good Luck
Posted on Jul 02, 2008
  • 4,234 Answers
Just to be sure that we are all on the same page, please confirm the items listed below:
1) The cable from DVD to TV is Red/White/Yellow connected to AV or Video input on TV (please specify which input)
2) The TV is set to accept input from Video 1 (for example)
It is possible the the output buffers have failed, but that is a very rare occurrance. Please verify the above and we'll go onto the next step.
Dan
  • 983 Answers
I think the cables are not connected correctly into the tv...
you must insert the cables of the dvd to the line in ports according to the colour ...
you might have inserted it to the line out ports ...
check this first ...
  • 4 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 02, 2008
    i mean you must insert the cables of the dvd player to the line in port of the tv ....
    if you have inserted correctly to the line in port then there may be some problem in the cable just have a check with the cable if required replace them
    if the changing the cables doesnt solve the problem then there may be some problem in the ports of the dvd or in the tv ....
    just have a check with this ...
    you are using trying to use both the dish tv cable & to play dvd then it might not work due to this ..
    so you have to first disconnect the cables of the dish tv & then you must insert the cables of the dvd ...
    this will solves your problem ...
    try these & let me know what happens ...
    if you are using trying to use both the dish tv cable & to play dvd then it might not work due to this ..
    if you are trying to use both the dish tv cable & to play dvd then it might not work due to this ..
    Sergeant:
    Champion:
  • 310 Answers
Check the cables is working properly.........
  • 2,326 Answers
Do you see any errors when you insert a DVD in the DVD player?
  • Jaime Hernandez Jul 02, 2008
    If you see the numbers rolling on the DVD player screen, it means the DVD is working.
    Do you hear the audio from the DVD you're playing?
    I would suggest to unplug the yellow cable from both the TV and DVD player and use the red color instead the yellow, just to eliminate a defective cable.
    Are you connecting the DVD player directly to the TV?
    Make sure you press INPUT button on remote to select video 1 or video 2 input to switch the video source(s) to get the video.
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How do i put it to play dvd player
  • Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
  • 2
    Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
  • Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
  • 4
    Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
  • 5
    Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
    Car Tuning
  • May 24, 2012 | Initial HDTV-320 32 in. LCD TV
    It won't play dvd's in color
    Please check the type of disc that you're playing.
    Generally, if the NTSC format disc being played in PAL Player or vice versa will cause this issue. Please use the NTSC format disc in NTSC player and PAl disc in PAL player.
    Please check if the Player is connected to the display device with the correct cables and to the correct jacks.
    Please make sure to connect the Component OUT (Red, Blue, Green cables) to the Component IN (Red, Blue, Green).
    If you are using the Compiste connection (Yellow, Red and White), please connect the Video OUT of the Player to the Composite or Video IN on the TV using the Yellow cable and Red and white for audio according to the color codings.
    Please try with different jacks on the TV to confirm if the issue is with the Jacks on the TV.
    Please try power resetting the TV and check if that helps.
    Turn off the Player.
    Unplug the Player power cord from the electrical outlet.
    Let the Player remain without power for 60 seconds.
    Plug the power cord back into the electrical outlet.
    If the issue is still unresolved, the Player needs to be Serviced at the Authorized Service Center.
    Mar 30, 2011 | Sony DVP-NS50P DVD Player
    I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
    You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
    Feb 07, 2010 | Toshiba SD-2800 DVD Player
    New lcd tv and dvd player is playing movies in black & white
    1. Verify connections are color coded.
    2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
    Jul 04, 2009 | Coby DVD-536
    I can't set up DVD player correctly to record t.v. shows
    ok let's start from simple connection.we'll use color coding,let's say rca plug. yellow plug is video.from DVD video out is yellow and to the tv is video in. white and red is for audio.if your tv is 5.1 compatible then follow the label on your DVD and insert it to its corresponding label on your tv.then still if your using a separate audio amplifier only the yellow/video plug is used.
    May 16, 2009 | Toshiba DR410 DVD Recorder
    I just purchased a Sony DVD player...DVP-SR200P. Plugged it in and have no color...movies play in black and white only.
    Hello cherylsacket,
    Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc.com
    May 10, 2009 | Sony DVP-NS700P DVD Player
    Have set up a new SONY DVD player. How do I set my RCA Cable TV so I can play a DVD. My Channel Code is #3 on the TV
    use the color coded wires that were supplied with the DVD player plug them into the inputs on your rca tv then use you remote and there should be a button that says input i know my rca tv does. Then you push this button and it lets the tv use the input plugs.If there is more than one plug in on your tv push the button till you see your DVD players on screen menu.
    God Bless Greg
    Nov 15, 2008 | Computers & Internet
    Sony dvd dvp ns575p
    watch the cables of YcBcR and install them correctly.
    Jul 26, 2008 | Sony DVP-NS575P DVD Player
    Dvd screen is pink
    If you are using component cables to connect the DVD to the tv make sure you have the red,blue and green colors on your cables matching these colored jacks on the tv and DVD jacks. If one of these cables is plugged in wrong or not plugged in it could cause this. Good Luck
    Jan 04, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    Televison & Video Logo
    47 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
