Question about Whirlpool Dryers
Needs a new balance wheel on the left as you face the machine. How do you replace the wheel. Dryer is a whirpool model LAI5521 gas dryer.
  • Hjalmer Lamminen
    Hjalmer Lamminen May 11, 2010
    These are called rollers that the drum rides on.
    If a front loader then you need to remove the front panel by removing bolts .
    Scholar:
  • 170 Answers
They usually sell these in pairs at an appliance parts store.
Posted on Jul 07, 2008
Lint filter won't go back in whirpool
something more than likely fell into the lint trap area. Here's a general walk through that should help you get There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design.it apart.
Jun 02, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Where is the serial numbers located on the whirpool washer and dryer. its the basic ones
Normally the dryer model and serial numbers you are looking for is located on the drier door face of the machine where the door meets it. Look up top normally left hand side.
If it is not located there then maybe on the back of the drier.
Please rate me
Sep 13, 2010 | Dryers
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
I have a whirpool dryer model ler4634pq. I will not heat. I had the heating element and replaced the theromstats on the element but it still does heat. I had the switch checked. I checked to make sure hose...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 13, 2010 | Whirlpool LER4634PQ Electric Dryer
Dryer vibrating with overheating smell
The vibrating is usually the blower wheel not being balanced or worn and not spinning, therefore it does not blow enough air and therefore the system overheats-----and so, the smell. Some models need to be serviced from the rear, others need to have the front face removed to access the blower wheel assembly. The blower wheel is approx. $25 part but you need the skill to access and replace it properly. Goodluck, Macgivor
Dec 27, 2009 | Frigidaire Dryers
Trying to replace the dryer belt on a Kenmore Dryer
Good day,
That is a known defective part. Go to any appliance parts house and get the model with a wheel on it. The counter men will know what you need. Yes, it's made by Whirpool.
Directions below.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 05, 2009 | Kenmore Dryers
Our whirpoolgas dryer is not hot.We changed the
when you start you dryer and it got hot little bit and then won't got hot again? if yes then you may need new flame sensor..or if you can see your dryer igniter turn on your dryer and watch..you heard click sound then igniter will glow then one more click sound and should see flame..ok watch for 10 min..if after click sound igniter glow and other click flame will not apper then you need new gas valve..good luck..let me know it help or not...thanks..
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
I have a gas whirpool senseon dryer model number ggw9868kq0 that won't heat up all the time. The heating element lights up and then goes out 10 seconds later. The thermal fuse is good and I replaced the...
Hi, If the ignitor glows and then shuts off before you get a flame, then you will need to change the coils on the top of the gas valve. This is the most common problem with the gas dryer not heating consistant. Make sure your venting to the outside is cleaned out. A plugged went causes the coils to go back quicker.
I hope this helps and please let me knw if I can assist you further.
Thanks
Vic
May 11, 2009 | Whirlpool LGR5636L Gas Dryer
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
