Question about Samsung SRS20DTD Side by Side Refrigerator
Samsung refrigerator icing & draining
Has samsung recalled there side by side refrigerator models rs253babb model.  Is it a design flaw which doesn't allow for the proper drainage?  Which in turn causes icing & not cooling.  I was told this by a tech.  Thanks.
  • Gary Lee Hermsmeier May 06, 2009
    Samsung RS253BABB-XAA Refrigerator
    "Refrigerator" side does not drain properly - when it goes through a defrost cycle water runs onto the floor.
    It finally stopped cycling at all and simply maintains 53 degrees on the refrierator side. I just removed the interior covers and found that the coils are completely covered in ice.
    I am presently defrosting the coils in hopes that things might return to normal (come to think of it - this seems to be normal for this refrigerator).
    This problem began when it was still under warantee but since no one seemed to know how to fix it I am working on it myself.
    NO MORE SAMSUNG !
    Time to start an anti Samsung Blog -
    Would go nicely with my Princess Cruise Sucks Blog !
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
vanni7
  • 163 Answers
SOURCE: SAMSUNG REFRIGERATOR MODEL SR-368 freezes and no cooling.
Hi!!! You have a defrost problem.You need to change the defrost timer mechanism.In Samsung frig the defrost timer is in the main pc board..Good luck..
Posted on Jan 05, 2009
landsend
  • 1066 Answers
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Posted on Mar 27, 2009
SOURCE: control panel not working Samsung refrigerator
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Posted on Jul 26, 2009
Macmarkus
  • 2605 Answers
SOURCE: Samsung Refrigerator model number RS2630SH Getting
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor...
i.e.
Your actual condensor fan assembly may differ in appearance, but generally this is what to look for.
But just so you know, the amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Regards,
Macmarkus :)
Posted on Dec 01, 2010
Samsung side by side refrigerator not cold
Defrost problem. If ice builds up on coils behind the back panel in the freezer it will prevent cold air from being blown to the fridge.
Nov 23, 2017 | Samsung Refrigerators
I had ice over my fan in the fridge side i have a Samsung French door fridge the fan had ice all over it now it is not working
Defrost the ice with a hair dryer and clean the drain below the evaporator, then try it. Samsung dual evaporator models are well known for this flaw. Like my help? What is the model number of the fridge?
APPLIANCE 911
Apr 14, 2016 | Samsung Refrigerators
How to check fan in samsung srs585hdis
Not really a good way to explain how to get to the fans but looking at the=> SRS585HDIS Parts Diagram may help you see what is in the way. You also can contact Big Warehouse Spares. Parts for your model HERE=> SAMSUNG Refrigerator SRS585HDIS (RS21HDUPN1/XSA) Parts If this refrigerator is like most dual evaporator refrigerators made by Samsung the fan will not be the problem. The problem is a design flaw that causes ice buildup on the fridge side evaporator. You can clean the defrost drain and manually defrost the evaporator with a hair drier.. That fix should last a couple months unless there is a door seal problem causing excessive moisture buildup on the refrigerator side evaporator. I am here should you have any questions, Thanks John Tripp Appliance 911
May 16, 2014 | Samsung Refrigerators
Samsung model#rs2577bb freezerworking good refridgerator not maintaining temperature
Not really a permanent solution for Samsung refrigerators with a evaporator inside the fresh food section. You will need to remove the shroud housing the evaporator and clean out the drain opening along with removal of any ice buildup. User Manual HERE
Here is a link to a troubleshooting page that covers your model=> HERE You need to clean and make sure the sensors at base of evaporator are clean and function properly. Also insure condensate drain below evaporator remain clear of blockages ice/gunk. Parts breakdown can be found HERE. I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 12, 2014 | Samsung RS2534 Side by Side Refrigerator
Makesvery little ice
Make sure you pull the ice cubes periodically from the back of the ice tray to the front. If the back of the tray is piled past a certain point the unit will think the ice tray is full and stop ice production. This was a design flaw most samsungs. Hope this helps _MJ_
Apr 27, 2010 | Samsung RF265AA Bottom Freezer French Door...
Model rs2534ww side-by-side Samsung frig. After power interuption to the home, interior lights work, but digital display is blank and compressor won't run. How do I fix this?
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Dec 03, 2009 | Samsung Refrigerators
Samsung RS253BABB. Where is the water pump??? I press the switch for the water dispenser and I can hear the pump running but no water comes out. The ice maker works so its getting water to the unit through...
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 21, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Evaporator freezing up, refer side.
There is a blanket type of heater stuck on the wall behind the coils.  However,  my tech guy checked the heater in our fridge, and he said it was ok.  The problem seems to be that the sensors and main circuit board do not turn the heater on - this is an inherent design flaw, and may not be able to be fixed.  There are 100 complaints about this this on consumeraffairs.com (usa),  and tons more in England.   This a very large problem which Samsung does not want to address, probably because of cost.  I'm seriously thinking about taking them to small claims court.
Jun 07, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge side began freezing everything then the fan
Generally speaking, sounds like you may have the frozen condensor problem that is so common
because of the design flaw in the Samsung products.
Turn it off, empty the freezer.
Study the back and look for formed ice around the seams.
So it got too cold, and now it is still too cold, or not cold enough ?
May 08, 2009 | Samsung RS2556 Side by Side Refrigerator
Ice dispenser
I bought the PSS26MSWSS model (GE Profile) in August 2007. I have had numerous problems with the icemaker. It was out of warranty for the last two visits (Oct 2008) but GE warranteed anyway because of the previous problems I had had with the icemaker.
The last time the repairman came out I asked him if this latest part would "fix" the problem. He said it would help it but not fix it because there was a design flaw with the back/rear dispensing icemakers. I paid around $2,000 for this frig. I called Lowe's and told them of the problem and they said they would replace the refrigator for one of equal value.
Other than the problems with the icemaker I thought this was a very nice refrigator. However, I don't think I will buy another GE. If they knew there was a design flaw they shouldn't have sold these refrigators or had a recall when they became aware of it.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
196 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
