Question about IBM Wheelwriter 30 Typewriter
IBM Personal Wheelwriter 2
When I type the whole letter doesn't print. It seems the top of the letter is cut off.
  • IBM Master
  • 3,594 Answers
Look at the ribbon and see if the letters are on the very top of th ribbon. If so on the front of the carrier there is an eccentric screw for adj. ribbon height. Loosen the lock nut W/ a small 9/32 wrench and adj screw to raise ribbon. Be sure to check L/O with the underscore as you can get it to high.
DickyO
Posted on Jul 03, 2008
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
Jun 20, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 30 Typewriter Logo
171 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
