Question about Konica Minolta Dimage Scan Elite 5400 II Film Scanner
Cannot start up the scanner as the slide holder wizzes fast
To start the scanner by inserting the slide holder results in error message, close scanner door but the wheel mechanism to carry the slide holder wizzes so fast and hence nothing happens save this error message.
  • drwalters Jul 02, 2008
    I have a continuous problem of the slide holder initiating the wizzing wheel that is supposed to carry it; when I turn it off and wait before turning on again, the same error message.. close door to scanner and the same wizzing of the slide holder.
    Master:
  • 848 Answers
Check the power supply given to it
Posted on Jul 02, 2008
    Sergeant:
    Champion:
  • 310 Answers
Just trun off for half hour and then try it.........
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
Aug 12, 2009 | HP LaserJet 4600 Printer
Getting true color on slide scans
Make sure you have the emulsion (image) side of the slide towards the scanner sensor. Some scanners have a special setting for film still in slide holders to correct for focus. You may need a photo edit program to help with color and density. I find no difference from 35mm to split 5x7s altho bigger is always better.
Jul 03, 2009 | Nikon LS-9000 Film Scanner
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
goodluck
cheers
Dec 22, 2008 | HP Scanjet 4850
Will not scan photos, only slides
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
May 05, 2008 | Canon CanoScan 8600F Flatbed Scanner
Film holder problem
try this
Turn on the scaner (diode is blinking), then run aplication DS Dual3
After start application you sould hear the transport mechanism test.
The green diode should light permanently (important).
Push deeper the holder.
Jarek
Jan 29, 2008 | Minolta Dimage Scan Dual III Film Scanner
KM DiMage Scan Elite 5400 II
I have same problem..Are you find answer!? Thanx!
Graksi
Dec 03, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Konica Minolta Dimage Scan Elite 5400 II Film Scanner Logo
149 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
