Question about Philips 27PT6441 27" TV
Audio I have a picture on the screen but no sound. The tv is working on a delay from the remote. I adjust the volume up and it takes a minute and the numbers change however there is no sound, I push mute and it shows the speaker with the X after a minute. Nothing seems to be working, any suggestions.
  • onlyvipallow Jul 11, 2008
    I have the same problem. Picture is working but there is no audio. When I turn up the volume I can hear a slight buzz.
  • 30 Answers
I had thhis type of TV and had it serviced by a TV repair shop and they told me there is a small control board that has gone bad and costs $180.00 to replace. TV is not worth fixing.
Posted on Jul 25, 2008
Hitachi tv troubleshooting
It sounds like it has a Night Mode set, or another volume limiter. Check the Menu for Audio options, and/or Night Mode etc.
May 24, 2014 | Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
There is no sound coming out of the tv
If the volume on screen can be adjusted, the output stage is possibly faulty. Maybe a fuse link on the audio section.
Mar 26, 2014 | Televison & Video
No picture, just sound on Etec Flat Panel 40A99
Video circuit is separate from the Audio circuit. The main controller may switch to Audio, but if the unit is damaged from a power outage; part of the circuit board may not function. Needs professional servicing.
Feb 26, 2014 | Cars & Trucks
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
No Picture or sound in TV Mode
Are the RCA cables matching(in tv to out sources.audio to audio and video to video)?And make sure the cables are in working condition
Nov 15, 2017 | Sceptre Naga III X27SV 27 in. HD-Ready LCD...
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Delay between the actual TV volume and the sound from the Speaker
The time delay is likely caused by taking the audio signal from the TV rather than the source. I would need to know more about the components in your system and how you have them currently connected to be of further assistance.
Feb 28, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Philips 27PT6441 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
