Question about HP Scanjet 5500c Flatbed Scanner
Power supply for a 5500C
I am missing the power cable for a 5500C HP Scanner. None of HP's documentation for the scanner includes the power supply information. Does anybody know what the output power specs are for the power cable. I probably have an extra power cable here, but I need to know the output specs.
Thanks,
  • deb_schoenbe Jul 25, 2008
    need replacement power cord
Delta Electronics
AC Adapter model ADP-36XB REV. B
Input:AC 100V-120V~850mA 50/60Hz
Output: 24V 1500mA LPS (Center positive)
Made in Thailand
Posted on Sep 21, 2008
This is the information I found online after searching eBay for a power adapter for the ScanJet 5500c:
C7717-84200 Power Module : Power module (wall mount type, Delta ADP-36XB Rev. B) - 100-120VAC, 50-60Hz input - 24VDC, 1.5A output - 3-prong connector, grounded - Detachable power cord not needed (USA, Canada)
Posted on Dec 13, 2008
When starting up the software says the scanner is not connected although it is making the right noises
1) Check Data cable (USB) connecting ok
2) Fully remove scanner software / driver. Then Re-install scanner software / driver.
Mar 28, 2011 | HP Scanjet 5500c Flatbed Scanner
Scanner showing error 04 and cant let me scan
Disconnect the power supply from the back of the scanner base.
Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
Reconnect the power supply and turn on the scanner.
Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
now try to scan the document ..........
Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
Scanner will not initialize
When I try to scan a picture a message comes up that says "A problem prevented the document from being scanned." What do I do?
Sep 16, 2009 | HP Scanjet 5500c Flatbed Scanner
How do I uninstall my HP 5500c scanner ..I have a Mac os X
use following instruction and uninstall the scanner.
open the control panel
2-open add/remove program
3-click on scanner and then remove...
Apr 13, 2009 | HP Scanjet 5500c Flatbed Scanner
We have a HP Scanjet 5500c Scanner and when you try to scan a sheet the image scan all black, do you know why that is happening.
See the item is placed correctly on the scanner glass or in the ADF.Make sure that the item you are trying to scan is placed face down onthe glass, or face up in the ADF. Ifyou are using the ADF, there might be a page on the scanner glass.Raise the ADF unit and remove any pages on the scanner glass. If you are using the ADF, the ADF window might need to be replaced.
If that is okay, Please check this link.
Jan 07, 2009 | HP Scanjet 5500c Flatbed Scanner
Black image
I have an HP 5470c flatbed scanner. It started with partially black scans, and progressed finally to completely black pages. Tried here for answers. Found none. So I opened up my scanner, figured I had nothing to lose. Thought it might be the ribbon cable attached to the moveable tray. Was RIGHT!! Immediately saw a small frayed piece where it was rubbing against the tray. Used some Scotch Long Lasting Tape to re-connect. EUREKA. Problem fixed!!
Jul 04, 2008 | HP Scanjet 5500c Flatbed Scanner
No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Jun 14, 2007 | HP Scanjet 5500c Flatbed Scanner
HP Scanjet 5500c Flatbed Scanner Logo
981 people viewed this question
Seeker5211
Seeker5211
