Question about Asrock P4I45GV R5 Motherboard
Virtual Memeory My laptop keeps telling me that my virtual memory is too low, what does this mean and how can I fix it?
  • 36 Answers
Farc
Main memory (in general we call RAM) r use for those protions of code and data that are actively being used. and the rest of program is stored in virtual memory of the disk. for this reson we can deal with grater amount of data or coad then ram. this is reserve space in disk in windows xp "pagefile.sys" control virtual memory.
To solve ur problem right click of "My computer" then click on "properties" then click on "advance" tab, click "setting" under Performance, then click on "advance",and then click on "change" click on "system managed size" radio button" and click on "set"( if it already selected "custom size" set initial size 500MB Maximum size 2000MB and click on set tab) then ok and again ok at last ok. and restart ur machine.
(if "system managed size" not solved ur problem then should select custom size and give the above size or as per your choice)
thank for asking
Buddhadev
Posted on Jul 02, 2008
My computer often has the message: virtual memory is low; windows is increasing virtual memory. What can I do to fix this?
Uninstall programs not used at all. Even the ones that came with this PC when new OR purchase more memory
Jul 17, 2010 | Dell Inspiron 8500 Notebook
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Tip
Virtual memory Information.
Tutorial Objective
This tutorial talks about anything about the virtual memory and how much virtual memory you need for your system.
Tutorial Introduction & Background
Today application is getting bigger and bigger. Therefore, it requires a bigger system memory in order for the system to hold the application data, instruction, and thread and to load it. The system needs to copy the application data from the HDD into the system memory in order for it to process and execute the data. Once the memory gets filled up with data, the system will stop loading the program. In this case, users need to add more memory onto their system to support that intense application. However, adding more system memory costs the money and the normal user only needs to run the the intense application that requires the memory only for one or two days. Therefore, virtual memory is introduced to solve that type of problem.
Terminology & Explanation
There are two types of memory, which are as follows:
* System Memory is a memory that is used to store the application data and instruction in order for the system to process and execute that application data and instruction. When you install the memory sticks to increase the system RAM, you are adding more system memory. System Memory can be known as either the physical memory or the main memory.
* Virtual Memory is a memory that uses a portion of HDD space as the memory to store the application data and instruction that the system deemed it doesn't need to process for now. Virtual Memory can be known as the logical memory, and it controls by the Operating System, which is Microsoft Windows. Adding the Virtual Memory can be done in system configuration.
Tutorial Information & Facts or Implementation
Virtual Memory is a HDD space that uses some portion of it as the memory. It is used to store application data and instruction that is currently not needed to be process by the system.
During the program loading process, the system will copy the application data and its instruction from the HDD into the main memory (system memory). Therefore the system can use its resources such as CPU to process and execute it. Once the system memory gets filled up, the system will start moving some of the data and instruction that don't need to process anymore into the Virtual Memory until those data and instruction need to process again. So the system can call the next application data and instruction and copy it into the main memory in order for the system to process the rest and load the program. When the data and instruction that is in the Virtual Memory needs to process again, the system will first check the main memory for its space. If there is space, it will simply swap those into the main memory. If there are not any space left for the main memory, the system will first check the main memory and move any data and instructions that doesn't need to be process into the Virtual Memory. And then swap the data and instruction that need to be process by the system from the Virtual Memory into the main memory.
Having too low of Virtual Memory size or large Virtual Memory size (meaning the size that is above double of the system memory) is not a good idea. If you set the Virtual Memory too low, then the OS will keep issuing an error message that states either Not enough memory or Virtual too low. This is because some portion of the system memory are used to store the OS Kernel, and it requires to be remain in the main memory all the time. Therefore the system needs to have a space to store the not currently needed process data and instruction when the main memory get filled up. If you set the Virtual Memory size too large to support the intensive application, it is also not a good idea. Because it will create the performance lagging, and even it will take the HDD free space. The system needs to transfer the application data and instruction back and forth between the Virtual Memory and the System Memory. Therefore, that is not a good idea. The ideal size for the Virtual Memory is the default size of Virtual Memory, and it should not be exceed the value of the triple size of system memory.
To determine how much virtual memory you need, since the user's system contains the different amount of RAM, it is based on the system. By default, the OS will set the appropriate size for Virtual Memory. The default and appropriate size of Virtual Memory is:
CODE
* 1.5 =
For example, if your system contains 256 MB of RAM, you should set 384 MB for Virtual Memory.
CODE
256 MB of RAM (Main Memory) * 1.5 = 384 MB for Virtual Memory
If you would like to determine how much the Virtual Memory is for your system and/or would like to configure and add more virtual memory, follow the procedure that is shown below. The following procedure is based on windows XP Professional.
1-1) Go to right-click My Computer and choose Properties
1-2) In the System Properties dialog box, go to Advanced tab
1-3) Click Settings button that is from the Performance frame
1-4) Once the Performance Options shows up on the screen, go to Advanced tab
1-5) Under the Advanced tab, click the Change button from the Virtual Memory frame to access to the Virtual Memory setting
Then the Virtual Memory dialog box appears on the screen. In there, you are able to check how much the Virtual Memory you set. If you would like to modify the size of Virtual Memory, follow the procedure that is shown below.
2-1) In there, select the drive letter that is used to install the Operating System
2-2) Choose the option that says, "Custom Size:"
Once you choose that option, the setting for Initial Size and Maximum Size become available for you to set. Initial Size (MB) means the actual size of Virtual Memory, and Maximum Size (MB) means the maximum size of Virtual Memory that is allowed to use.
Let's say if your system contains 512 MB of RAM, then the ideal setting for the Virtual Memory is as follows:
CODE
Initial Size (MB): 768
Maximum Size (MB): 1500
Once you are happy with that Virtual Memory size, click the Set button from Paging file size for selected drive to apply the setting for the Virtual Memory size. Then click the OK button to apply the setting.
That's where you can manage and configure for the size of Virtual Memory.
Additional Information
* To maintain the good overall system performance, you should be using the default size of actual size for Virtual Memory and the triple the value of the size of the main memory for the maximum size of Virtual Memory. If you find that main memory plus virtual memory is not big enough to load the intensive application, then you will need to add more main memory onto your system.
Search Keyword
virtual memory
on Dec 02, 2009 | Computers & Internet
Over a couple of months my Toshiba Satellite Pro Laptop keeps telling me I have very low disk space. Ive removed all my pics, music and alot more! it is pratically empty now! I regulary have to run Disk...
'Low Disk Space' Could be talking about your virtual memory. Sounds as if your RAM is experiencing problems and your Virtual Memory cache is not high enough.
Jun 16, 2010 | Computers & Internet
I have a error memory 108 whats this mean
Increase virtual memory !!
Right click my computer - click properties - click advanced tab - click settings under performance - click advanced - increase virtual memory !!
Hope it fixes !!
Thanks
Sep 09, 2009 | Dell Inspiron 6400 Notebook
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
LG LW 20 virtual memory is low??
You could be using a progam or have background services that eats up your memory and the page file on advanced settings could be set to a specific range.  You could set it to system managed that could fix the issue. Right click on computer, select properties, select advanced system settings, select advance tab, click on settings under performance, click advance tab, then you can check out virtual memory from there.
Hope this helps
Sep 12, 2008 | LG LW20-EV Notebook
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Asrock P4I45GV R5 Motherboard Logo
49 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
