Question about Vermont Casting VCS4017 (NG)
I broke the flame divertor that sits on the pilot light tube and can't seem to find that part. The exploded views I find are confusing. The "divertor is just a piece of metal ("T" shaped) that seems to snap around the pilot tube. Can anyone help. Model # RDV40 2770 2776. Thanks
  • 2,778 Answers
Contact the manufacture
Posted on Feb 09, 2018
    Top Expert:
  • Vermont Casting Master
  • 57,204 Answers
Try the manufacturer's website .
Posted on Feb 03, 2018
2 Suggested Answers
SOURCE: Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Posted on Oct 13, 2009
8" yellow flame shooting out of ignition tube when running. No adjustments that I can see on the (Honeywell) gas cut off/pilot valve.
yellow flame is an indication of incorrect air mixture
as it is gas I would suggest that you seek the services of an accredited gas specialists to do any adjustments or repairs
Nov 06, 2015 | Heating & Cooling
How does the thermocouple in a gas geyser work in a junkers wall mounted gas geyser?
Thermocouple sits in the pilot light flame and generates a small amount of electricity that tells the control that the pilot light is lit. If the pilot goes out, it shuts off gas so the place won't fill with gas and explode.
https://www.youtube.com/watch?v=igxYxhD82lU
Thermocouple What is Thermocouple How does Thermocouple work
http://en.wikipedia.org/wiki/Thermocouple
Thermocouple Wikipedia the free encyclopedia
Feb 07, 2015 | Heating & Cooling
RHFE Rinnai 551FT gas heater is not working after 7 years
see this steps and fix it. God bless you
If there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below).
If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
To light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps:
Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Sep 30, 2012 | Heating & Cooling
Atlanta Stove AIT3 model wall stove. will not light unless pilot light is held down...
Most pilot flames for gas burners are controlled by a safety valve. This model has a pilot safety valve. The safety valves function is simple, if the flame goes out for whatever reason the vale shuts the gas flow to the pilot light. The safety valve is controlled by a device that sits right next to the pilot (small cylindrec tube ( thermopile) that senses the pilot flame either by heat or dc current. To ignite the pilot light you have to manually hold down pilot light button until the the thermopile is hot enough (usually 5 to 20 secs), after that time, the thermopile will allow the safety valve to open. Check to see that the pilot's flame is making contact with the thermopile. If it is not, the pilot flame will require cleaning and or adjustment. If it is making contact, the you might need to replace the safety valve and the thermopile.
Feb 17, 2018 | Kitchen Ranges
My pilot light has gone out on my gas furnace, I lit it again, but its not staying lit. Seems like the switch makes it go out.
Probably not the switch, MUCH more common is the sensing tube. This is the copper tube that goes into the gas control valve, and the other end is TOUCHED by the pilot light flame.
(The flame heats this tube and then this allows the pilot to remain on. The thinking is if the pilot were to go out, it is important to stop the flow of gas....)
These sensing tubes are readily available, but different across brands, so be sure to get the correct one for your unit. Easy swap out, do not kink the tubing and put the sensing end in the same position as the old one, relative to the pilot flame....
The start proceedure requires that you override the tube, light the pilot light, and continue to hold the override for xxx amount of seconds. How long differs, I observe the flame and then slowly let off the override, ready to re press if the flame were to lessen or go out.....
Mar 11, 2011 | Heating & Cooling
When i try to light the pilot it lights, but when i let go of the button it go,s out, it takes a long time to get it to stay lit then sometimes when i get it lit and turn the flame up and walk away it gos...
Make sure the pilot light flame is bathing the thermocouple; not too close, not out of the flame. If it seems in the right part of the pilot light flame, then the thermocouple may be failing; they only produce a few thousandths of a volt and it may be defective now. The thermocouple will look like a tube with a closed end and a thin tubing attached to it going to the regulator.
Jan 11, 2011 | Desa International Heating & Cooling
How do I know where to light the pilot on my wall heater? I'm not exactly sure where the pilot is. I know where the button is and the pilot knob but do I need to turn the gas on and how far should I turn...
I can try and help. Get a working flash light. If you know where the gas valve is, good I will take you from there. On the gas valve you will find a 1/4" diameter aluminum tube and a 1/16" diameter copper wire both screwed into the valve. Follow the larger of the two tubes toward the heat chamber. The tube will enter inside the chamber and you may have to unscrew a cover to get to the pilot. The tube goes to the pilot assembly. If you have button that snaps when you push it in, that is the pilot starter. Look thru a small viewing port and snap the button. You should see a blue spark. This is where your pilot assembly is.If there is no spark, your sparker is broke. You will have to use a ling match or gas grill starter to light the pilot. OK so if you have good spark, turn the gas valve knob to Off. Now turn it to Pilot and depress the knob into the gas valve. It should go in about 1/2". As you hold the knob in, snap the sparker button a few times and continue to hold the knob in. Look in the little window for a flame. Continue to hold in the knob for about 30 seconds after the flame lights. Now let the knob out and check that the flame is still lit. If it is, turn the knob to the On position. You should be OK from there. If you had to use a match, prior to putting the knob to the on position, replace any screws or plates you had to remove to get to the pilot. Good luck!
Dec 03, 2009 | Williams 3003622 Ceramic Wall Mounted...
Problem lighting natural gas roomheater sunstar corcho 18,000 btu
sounds like the thermocuple is bad, it is a small copper line coiled up with a larger end that sits in the pilots flame. it tells the control valve that there is a flame and it is ok to open the gas valve. You can replace them very easily you just have to match it up to the right one. they are conected by a tube fiting on the control valve and a screw or sometimes just a clip near the pilot flame. True value stores carry them
Oct 17, 2009 | Dishwashers
Pilot lit, ignitor glowing, oven will not light
A pilot light and a ignitor do the same thing. no unit would have both.
Perhaps you are confusing the thermo-coupling for an ignitor. An ignitor (glow plug style) is ceramic with a conductive coating on the end powered by electricity supplied by two high temperature coated wires that connect to the oven controller.
A replaceable thermo-couple looks like a copper tube with a elongated bulb at one end and a fitting at the other. The bulb is placed in the pilot flame and the fitting screws into the gas valve.
I am looking at a exploded diagram for the model number you listed. The unit uses a "safety valve" with the thermo-couple incorporated into it. To see the exploded view, click here If
you are asked for a model #, use CPL1100ADW. In section 2, gas controls, Diagram location 17 is the safety valve. Click on the part photo for a better view of the valve.
If you have any questions, let me know. Hope this gets your unit up and running again.
Please take the time to give this solution a fix ya rating,
clarkco
Feb 19, 2009 | Magic Chef CPL1100AD Gas Kitchen Range
Pilot light will not stay on when egnition switched is released!
the little copper tube that sits in the pilot flame is faulty. this is called a flame sensor. replace this and you should have no problems
Dec 03, 2007 | Empire ECS HB06M HearthRite Heater
Vermont Casting VCS4017 (NG) Logo
156 people viewed this question
Top Vermont Casting Grilling Experts
Steve Allison
Steve Allison
Paul Carew
Paul Bade
Are you a Vermont Casting Grilling Expert? Answer questions, earn points and help others
