Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Mitsubishi WD52725 problem
The problem with my TV is that the green light constantly flashes quickly but the TV never comes on. What is causing this and what can be done to fix it? Thanks
  • 10 more comments
  • OUSooners Jul 09, 2008
    I have the same rapid flashing of the green light. I had previously been able to reset the TV by unplugging for a few minutes, however, this "fix" became progressively less successful. Now the TV will not reset or turn on. Thanks for any help.
  • harter03 Aug 23, 2008
  • CEDOMIR BLAGOJEVIC Sep 29, 2008
    when i plug in power green status start to blink bat can not start tv.after 20 min it go in red lump light
  • DzneeChannel Oct 12, 2008
    I recently had a power outage in my neighborhood. The TV was on at the time of the power outage. When power was restored, the green light was blinking but I was not able to power up the TV. I have tried unplugging the TV, resetting the powerstrip, system restore on front of the TV, other outlets, and I let the TV sit unplugged overnight, nothing has given me any success. The TV doesn't show any signs of power, no lights red, yellow, green or blinking.
  • msethji Oct 30, 2008
    I am having the same problem where my TV will not turn on at all. The green light on the Timer/Power button just flashes rapidly. I have unplugged the set for an hour, hit the reset button, etc, and still nothing.
  • jeffyoung21 Nov 01, 2008
    Same problem with me. The light continues to blink green but there is no picture. I can hear the tv fan running but there is no picture, not even a blue screen or snow. What can i do?
  • martyq1 Nov 27, 2008
    tv turns off the grenn light on the timer switch keeps flashing
    if I unplug the set and let sit for a couple of mins then plug it in the tv will come back on,
    but this problem keeps recurring
    has happened 3 or 4 times today
  • angelcolt Dec 01, 2008
    The TV shut itself off and the power/timer light started flashing green. I called Mitsubishi and they told me to unplug it for an hour then plug it back in straight to an outlet instead of the surge protector. If it still didn't come on, try to push reset button, if that didn't work, press and hold the menu button for 30 seconds. None of this worked.
    My husbands friend at work told him his did the same and it was the circuit board which cost $1500.00. The TV is not worth putting that much into if the warranty is only 30 days and it could go out again.
    IF anyone can help me with a cheaper repair, please let me know. I hate to trash this TV. It is only about four years old.
  • thewarner Dec 12, 2008
    My four year + 3 month old Mitsubishi WD-52725 went dead while watching HDTV. It did it before and power cycling the thing addressed the issue. This time the TIMER LED would not stop blinking. Which means that the start up process could not proceed due to some error. TV repair shop listed under the Mitsubishi site told me that he needs to ship it to the factory for repair with an estimate of 800$. I am not biting. It is not worth it. Looks like Mitsubishi is designing their TVs to fail after four years. The extended 4 yrs warranty I had died a couple of months before. I hated the noisy fan that would not stop on this TV so I am dumping it and buying Pioneer or Hitachi probably. Misubishi lost me since many folks are seeing the same issue. I believe that Mitsubishi is cutting corners buying cheapo parts that can't handle more that four years usage. From the sound of folks with the same issue, Mitsubishi should have recalled their product and fixed the issue as the issue is intermittent initially then becomes solid after four years it looks like.
  • janesalazar Dec 26, 2008
    I just got an mitsubishi WD- 52725 from my uncle who got a new tv, the green light is blinking fast and it won't turn on. How do I fix this?
  • Anonymous Jan 11, 2009
    I'm in the same boat. TV turns itself off and green light blinks. Sometimes the screen turns blue first and sometimes not. On occasion, I notice the picture starts to "****" a bit and I know it's about to go off. Sometimes it stays on for 2-3 hours, sometimes it goes off in 10 minutes. Painful.
  • kldn May 16, 2009
    I also have just experienced the flashing green light on my 4 year old Mitsubishi WD-52725. It will not turn on. I read on the internet that this is a common problem and that i can possibly repair it myself by replacing 4 caps. The TV dealer where i bought the tv says they can pull the chasis and return it to Mitsubishi and they will repair 4 different boards and this will take 4-6 weeks. The cost will be $750 of which Mitsubishi will pay $300 of it. What's the real truth with this problem.
Here is a website that will show some troubleshooting and how to do the repair if you decide to take it on.
http://www.techlore.com/article/24711/How-To-Repair-the-Mitsubishi-Blinking-Green-Light/;jsessionid=1FB725B21D45FBD2F1040A30705F884B
Posted on Jan 04, 2009
I'm wondering if it's worth purchasing a signal board that's used and working and how easy/difficult it would to install a new board on my own. I'd rather spend $150 on a new board than just throw the whole TV out the door.
Any input would be great.
Posted on Jul 30, 2009
I had a repairman out and I was told my DM board needs replaced. The estimate for repair is $1000.00. The TV is not worth fixing for that amount. He did advise me to call Mitsubishi since my TV is only a little over three years old. They may send the part for free and all you would have to pay is the cost of installation, which is a few hundred dollars, he said. When I called Mitsubishi, I was told I would need to fax them a detailed diagnosis and the original purchase receipt and that I should fax it to them so they could decide what they would do. I explained to them that I had the diagnosis with the estimate but it would not work because the estimate was not broke down in detail of the cost of part, cost of repair and tax. Even if I go through the process of getting a breakdown and looking up the receipt, they will not assure me they will do anything.
The big question now is, do I want ot put any more money into this TV just to have this problem again in three years? My decision was to go out and buy a Samsung! It has a warranty and I am told they stand behind their TVs.
Posted on Dec 10, 2008
  • Mitsubishi Master
  • 8,617 Answers
Leave a email at the following link with your model number and symptoms, they have various repair kits for your symptoms based on model and symptom.
http://servicemanuals.vstore.ca/
Posted on Oct 11, 2008
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
Green light flashing on TV. Cannot get it turned off. No pictur
Did you get yours resolved? I had the same thing. The repair guys called it the "flashing light of death". It indicated the TV is dead.
Jul 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi tv model # wd52725, the timer light is blinking nonstop green? do you know what the problem is? i cant seem to find anything in the manual thank you irene Irene_padilla@msn.com
Thats caused by failed capacitors on the DM board. You can get the V26 DM repair kit at www.tvrepairworld.com which should fix that issue. The kit contains the capcitors and the CD with detailed repair instructions.
Jan 03, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
Mar 06, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
1,865 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
