Question about HP Deskjet 6940 InkJet Printer
HP 6940 with flashing down arrow?
I have flashing down arrow on printer and when I push it the paper feeds out two sheets with nothing on it. The book says to check the back for jam and remove it and push (resume ) arrow to restart print job. I have turned off and still get flashing arrow when turn it back on.
Thanks for any help that you can give me, or put me in the ball park
Regards
Rich
  • rasoa Jul 08, 2008
    Same problem, I'm gonna kick this s*** if it still not work. I've unpluged it, got it out of network, re-installed it. I don't know what I could do else...
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
geemarie
  • 876 Answers
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
Posted on Aug 15, 2008
  • 277 Answers
SOURCE: My HP Deskjet 6940 printer won't print
the printer needs servicing.the steel rod on which the cartridge carriage moves sometime oiling that steel rod makes it proper other wise the whole printer needs to be opened and the cleaning and servicing needs to be done.
Posted on Mar 02, 2009
SecurityGuru
  • 100 Answers
SOURCE: My Deskjet 5740 has Resume light blinking, all
Sounds like it is expecting a different size paper than you have in it. In the item that you are trying to print confirm the page size. If it is a document that you download or someone sent you it could be in a different page size. To cancel it you will likely have to go into the printer settings and delete it from there then power off the printer and power it back on, this should clear the job. Windows will keep trying to print the job until it is successful or deleted. To see the print jobs double click on the printer icon then just highlight and delete it.
Posted on Jan 19, 2010
SOURCE: hp 6940 printer has flashing
Check the Encoder Strip (metallic) that runs the length of the printer in the back of the carriage. If it is loose the carriage will not line up correctly in the printer and cause the lights to flash. On the inside right of the printer behind where the carriage sets when you change the ink look to see if the metallic encoder strip has come off the hook. If so simply reattach it to the little metal hook and the printer should start working again.
Posted on Feb 01, 2011
Orange button continuously flashes on HP Deskjet 6940 printer and printer will not print.
it is problem ink cartridge or paper miss feed please chack it and solve your problem
thanks
Tareq
Jul 31, 2009 | HP Hewlett Packard Deskjet 6940 InkJet...
Printer Frozen with Resume Light On
The following steps to be done:
01. Please switch of the Printer and Desktop / Laptop.
02. Remove Both catridges 96 and 97 carefully.
03. Load 215.5x 279.4 mm (8.5 x 11.5 inch) paper in the Printer after switching on both printer and the machine.
04. Raise the Out Tray.
05. Slide the paper grade all the way to the left.
06. Place the paper in the tray, pushing the paper into the printer and check the Resume Light is flashing.
07 Place the paper in the In tray, pushing the paper into the printer until you get the flashing.
08. Slide the paper guide firmly against the edge of the paper stack.
09.Lower the Out tray.
Regards
Jul 26, 2009 | HP Deskjet 6940 InkJet Printer
HP 6940 rejects 8.5" X 11" glossy photo paper for printing
Is it a front feed and then the output is also goes out to the front? Coz if your glossy paper is to tough that it will not bend easily, this is what you get. Why not try to use a thin and more flexing photo paper if the outcome will be the same.
Usually when using thick paper the most desirable printer should be a top feed-front output with almost less than 90 degree bend.
Apr 24, 2009 | HP Deskjet 6940 InkJet Printer
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
Aug 08, 2008 | HP Deskjet 6940 InkJet Printer
Hp psc 1315 paper jam
2.
3.
4.
5.
6.
7.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam
Remove the back cover and look if there's any paper stuck in the feeding mechanism.
Feb 15, 2008 | HP DeskJet 6122 InkJet Printer
Hi there i need some help, I need to find out why my paper will not go into the feeder area of the printer. I have tried different ways and it just won't feed even though the rollers roll. Thanks call if...
This printer comes with major paper feeding problems, even on the FAQ for this printer on HP's website paper feed problem is the number 1 FAQ. It either misfeeds or won't feed paper. An average example is if you try to print a 6 page report, it will missfeed about 10 sheets to print 6, and you will spend a lot of time pushing the paper feed button.
Following the guidlines in HP's faq about this does nothing to improve the situation. HP basically denies any problem with the printer and wants the consumer to pay to ship and have the printer fixed, even if it is new. They will give you phone calls and emails with a lot of PR babble, but do nothing. Stay away from this piece of junk, HP is aware there are major paper feed problems, does nothing about them, and doesn't take it off the market.
Oct 28, 2007 | G7 Productivity Systems VersaJette M300...
HP Deskjet 6940 InkJet Printer Logo
1,360 people viewed this question
Ben Johnson
