Question about Mitsubishi WD73727 73" HDTV
Mitsubishi WD73727 - dark 1" line across top of screen
There is a dark line taking up about a 1" space along the top of my screen. It is almost as if the whole picture is not being projected on the entire screen. I have replaced the bulb, but it is still there. Anyone have this problem? It is a Mitsubishi 73" DLP 1080i tv.
Thanks!
  • beatlez Jul 02, 2008
    I should rephrase "dark line" and say dark blue shadow... any thoughts?
  • 179 Answers
SOURCE: MITSUBISHI WD73727 73" HDTV
the light engine has gone bad..contact mitsubishi consumer relations..all of these sets seem to be failing,,they can't keep enough of the engines working to replace them all
Posted on Nov 28, 2007
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
  • 65 Answers
SOURCE: I have the tv in standard mode, but I am unable to
I bet you are using a cable box or satelite receiver. If so check for aspect buttons on the remote that control these devices. I know comcast says "HD Zooom".
Posted on Apr 21, 2009
  • 65 Answers
SOURCE: I have a Mitsubishi 73 WD73837 DLP and I am
Sounds like a bad optical engine if you have the water color effect.
Posted on Mar 22, 2010
gopakumarg43
  • 74666 Answers
SOURCE: TV is 73" DLP Mitsubishi.
Hello
There are tow reaons for this fault. The first one is with the colour whell as you mentioned here. The second and most importan one is with its bulb itsef. Colour wheel won't cost too much. Just replace it first and see whether it helps you. If not, bulb may have to be replaced.OL
Posted on Jul 31, 2011
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Mitsubishi #35401 has only a white horizontal line across the middle of a dark screen. Please tell me the likeliest few parts to suspect. Thanks, RenThelp@aol.com, or 1 800 662 6231
Sounds like Vertical collaspe, Problem is in your Verical circuit
I need you to look on back of TV for correct Model number WD?
Thank You.
Feb 17, 2010 | Mitsubishi Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Nov 27, 2007 | Mitsubishi WD73727 73" HDTV
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Open Questions:
See all Mitsubishi WD73727 73" HDTV Questions
Mitsubishi WD73727 73" HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
