Question about Xerox DocuColor 12 Printer
Mailbox ,finisher xerox dc12
Wat's the nvm setting to enable mailbox and the finisher xerox dc 12 thank's
  • 62 Answers
I take you have a mailbox finisher. If so the finisher is plug and play with the dc12
Posted on Feb 20, 2009
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
Xerox DC12 Fiery EX12 Print missaligment
caopy can be set by NVm Code 720-001 for side A
720-002 for Side B
please note down initial values before changing it
Apr 21, 2009 | Xerox DocuColor 12 Color Copier
DOCUCOLOR 12 NO POWER UP
Hy, your dc 12 has a problem whith the ac driver pwb is the one with some relays on it close to the lvps pwb. The reley who have to mantain the current flow to the lvps is brocken. That is the solution.
Apr 19, 2009 | Xerox DocuColor 12 Printer
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
NVM settings
In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
Dec 24, 2008 | Xerox DocuColor 12 Printer
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox dc 12 mailbox finisher
its plug and play...you dont need to change anything
Jul 02, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
196 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
