Question about Intel Motherboard
Motherboard are dead
Hi there , i recenly switch my motherboard to a new casing but first it was working but know dead what can be the problem? i check everything allready
  • 864 Answers
Check the jumpers for everything.
Posted on Jul 02, 2008
Comp. does'nt turn on. power is good
Your question fails to provide sufficient information.
.."doesn;t turn on power good...."
do any lights on the pc illuminate
was it working before, and did it close down correctly
has it possibly been hit by lightning
have you recently opened the case to install new hardware?
Possible causes of a failed power up.
dead power supply
a video card not seated in its slot correctly
dud motherboard
motherboard installed incorrectly
no Bios battery on motherboard
faulty wall switch
faulty power pack switch
no ram installed
and on and on
thanks for using FIXYA
Oct 10, 2009 | Intel Motherboard
Asus A8N32 SLI Deluxe Motherboard audio problem
The new boards multiplex the connectors on the back panel to maximize use. Open the Realtek control panel and configure for sterio 2.1. Also, these new boards do not provide any power drive, so to get decent volume, you will need amplified speakers.
Oct 09, 2009 | ASUS A8N-SLI Premium Motherboard
HI, I have an Acer Aspire AM5641-B5540A. THE SYSTEM IS COMPLETELY DEAD. i HAVE RULED OUT A BAD POWER SUPPLY. WHAT DO YOU THINK COULD BE THE PROBLEM?
I understand now that you really checked out that power supply. Before we rule out a dead mobo, you should make sure the on off switch on the computer case is not broken.
Look on your mobo and find the power switch leads from your case power button to your mobo and remove them. Short out these two pins with a small screw driver and see if computer goes on.
http://www.pctechbytes.com/troubleshooting/detail.php?How-to-Bypass-A-Motherboard-Case-Switch-8
If that fails, and you checked your memory and CPU, then well, R.I.P. motherboard.
Hank
Oct 06, 2009 | Computers & Internet
No power what so ever!!
power supply could be dead in which case buy a new power supply, unless the motherboard is dead.
Mar 23, 2009 | E-Machines W3050 PC Desktop
The mysterious motherboard
You could possibly have a problem with the switch on the actual case. What you can try to prove this is trace to the motherboard fro the front panel the wires for the switch. Remove the connection off the motherboard and using a small flat screwdriver "short" the connection for those 2 pins. If the system then starts up you know you have a bad switch.
On another note the keyboard port could have caused the board to suffer "damage". I have experieced (25 years of this) keyboards stopping a system from booting. They would power up but never get to POST.
Is this motherboard the same that we are working on for the sound driver?
Dec 20, 2008 | Audio Players & Recorders
Just Bought The Mach 4 tried to test it with current power supply
Hi, one quick thing you can check is to see if the cable running from the power switch is plugged onto the right pins on the motherboard, it will most likerly say (pwr btn) next to the pins or something like that, it may also need to be a certain way round.Let me know what the outcome is if no good we can try something else. hope this has helped. Thanks
Onlinepc-Fix
lee
Mar 18, 2008 | Pine Technology Mach 4 KT400ANB...
Dead new motherboard
Are you using a 24 pin or 20 pin power supply? Can you confirm the power supply you are using does indeed work?
Mar 06, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Nothing comming on the pc screen
if all the fans are working including the processor and all the lights work black screen
is usually the processor is dead
hope this helps
Jan 04, 2008 | ASUS M2N-MX Motherboard
CF72
have had motherboards become static choked, and all you can do if this is the case is to leave it plugged in to power supply, but turned off, for a day or two. don't know if it works with laptops, but sure works great with "dead" motherboards.
Dec 10, 2007 | Panasonic Toughbook 72 Notebook
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith. If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins. Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names. The power and reset switch will work no matter witch way around you put them. The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer. Regards mistyman
Sep 03, 2007 | FIC FR33E Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
