Question about Panasonic SC-HT740 System
RECEIVER THE SELECTOR BUTTON DOES NOT WORK
  • 682 Answers
Please bring a contact cleaner from radio shack near you and apply the spray over selector and press it many times.
Posted on Jul 08, 2008
My Yamaha Rx a710 is stuck in stand by mode can't get any thing to work how do I do a hard re set on this receiver
  1. Set the unit to Standby Mode using the Power button. ...
  2. While holding down Straight button, hit the Power button. ...
  3. Use the Program Selector buttons to navigate to INIT-CANCEL and press the Straight button to select INIT-ALL.
  4. Turn off the unit using the Power button
Oct 20, 2016 | Yamaha Audio Players & Recorders
Why can I only select one set of speakers at a time ?
Press the speaker buttons you require at the same time! Not one at a time.
So if you want A & B then press both buttons together.
Aug 01, 2016 | Pioneer SX-1250 speaker selector switches...
Channels
Check your cables and then move the channel selector through all settings a couple of times. This will give some indication of the real problem. If the channel comes back after exercising the channel selector, then you have a "Furred up" selector. If the channel doesn't come back then you may have a failed amplifier in the amp.
Jul 21, 2013 | Panasonic SA-HE7 Receiver
Our 2nd zone won't work, we get the error saying check SP wires. The wires seem connected correctly. We also can't change the volume on zone 2. The Yamaha unit is working otherwise.
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Dec 26, 2010 | Yamaha RX-V2200 Receiver
I have connected PC to Yamaha and to SonyTV all with HDMI cable and when I play movie on my PC I can see the picture on TV but I can`t hear sound. What shoul I check to solve this problem? Thank...
Page 40 of your owners manual....
Rotate the INPUT selector on the front panel
(or set the operation mode selector to AMP
and then press one of the input selector
buttons on the remote control) to select the
desired input source.
Oct 19, 2010 | Yamaha RX-V2700 Receiver
Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Dec 28, 2008 | Sony STR-DA90ESG
Learning remote codes for my harmon kardon avr354
a) Place the two remotes so that their IR transmitters face each other
end to end, separated by about one inch. The
AVR 354 remote’s transmitter also serves as an IR receiver during
the learning process.– AVR 354 and Original Remote Head-to-Head
b) Press the Source Selector for the device mode you wish to learn
a code into, and place the AVR 354 remote in Learning mode by
pressing and holding the Learn Button until the Source Selector lights
up, then release.
Learning Remote Commands
c) Press the button on the AVR 350 remote you wish to program with
the new code, and the Source Selector will flash once. You may
learn a new code into the following buttons: Device Power On/Off,
Alphanumeric Keys, Last Button, Back/Exit Button, Menu Button, Navigation Buttons, OK Button, Disc Menu Button,
the four Teletext Buttons, Channel Up/Down, Volume Up/Down,
Mute and the Transport Controls (including Record).
d) Press and hold the button on the device’s original remote whose
code you wish to “learn” until the Source Selector flashes three
times, then release.
e) You may program additional buttons by repeating steps c) and d).
Press the Learn Button once to exit Learning mode, or wait for the
remote to “time out” and exit Learning mode on its own after about
30 seconds.
Dec 11, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Trouble getting a picture with a source selector
The input on your television monitor must be set to view the composite with the S video cable. You will not be able to view the component video unless you also have component video outputs going from the input selector to the television. After you have done that, you will also have to change your television input from "video 2" to whatever input you used for the component video hookup.
Dec 05, 2006 | Sony STR-DE685 Receiver
Panasonic SC-HT740 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
