Question about Nokia 3230 Cellular Phone
Message problem anytime i have a message my phone always display system error (-1) which make reading the message difficult
  • 983 Answers
This is happening because there is some problem in the firmware so ...
this firmware problem might have occured due to some virus attack or due to the sudden removal of the battery when the phone is in switched on condition or due to the sudden switch off of the phone when the battery charge was low ....
give restore factory settings once ...
this will solves all your firmware problems ...
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 09, 2008
Treadmil t733 shows E9 error and soes not start
Dear Sir:
Hello I hope you are o.k
I wil give some tipoe with this Error code:
Error 09 - Lower PCA Memory Test Errors
Description
Error 09 checks lower PCA memory locations during the power up test sequence. If a fault is
found during the power up test sequence, error 09 will be displayed. This error code is only used
on products utilizing the dual microprocessor system.
Possible Causes
1. This error message almost always indicates a lower PCA problem when it is consistently
displayed. Failures causing this error message to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the lower PCA
should be replaced. It is possible to see this error message displayed intermittently due to
external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in this message being displayed. Treadmills operating on
non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 28, 2011 | Exercise & Fitness
It does not start and shows E9 error
Dear Sir:
I hope you are o.k
I will help you:
Please follow this step:
Description
Possible Causes
Possible Remedies
If you need additional Help , please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Everytime I try to move a photo to another folder I get the message it can't be moved because it is "write protected". I want to remove that "write protected" from that folder. ...
Good day in regards to your issue you can do these steps. Make sure before you do this you must close other picture you're viewing in the same folder
here are the steps to follow
1. right click on the folder
2. click properties
3. Uncheck the read only box or
4. click advance then click on folder is ready for archiving
5. then click on OK or Apply
Note: This is a constant bug so it can happen anytime, make sure to have your windows updated always and always do a system check for errors
Hope this will resolve your issue. Have a great day and god bless.
May 22, 2011 | Computers & Internet
My sony ericsson v630i phone always displays operation failed anytime i load and application or games, whats the problem?
you are not downloading the correct java application for your phone
visit http://gallery.mobile9.com/c/sony-ericsson-v630-java-software_361/1/
to download more applications manly for your phone.
Mar 20, 2011 | Computers & Internet
Error message reads: Pace error #1
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed.
These errors messages almost always indicate an upper console problem when they are consistently displayed. Failures causing these error messages to be displayed are rare.
If the error message is consistently displayed when the unit is powered up, the upper console should be replaced.
May 23, 2010 | Precor 9.21 Treadmill
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Message display
In the even your new voice message alert flashing gets out of sync with your phone company's voice messaging system, you can reset it bact to the original "no messages waiting", non-flashing state. To do this, with the phone in the standby mode and in its cradle, press and hold find hs (find handset) on the base until the paging sound stops (about 5 seconds). The flashing will stop.
Apr 19, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
SYSTEM ERROR
Your solution depends on if system remain always in error status or it become usual after error message. First you should do hard formatting by removing sim and mmc then pressing four keys i.e. *,3,green send key and power switch simenteniously. Phone will get formatted and problem will be solved. If it doesn't work then we can say that there must be system file error. It can be resolved only by special tools like JAF or UFS.
Jan 02, 2008 | Nokia 7610
System error message(-1)
There might be some virus which can affect message supproting files. else corrupted phone memory data due to some prior installed software. Try to uninstall sms related symbian software installed before the problem actually took. if problem persists then Format your phone memory before have a bacup of phone date to memory card
Dec 20, 2007 | Nokia 3230
Nokia 3230 Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
