Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Brushes not spinning
I cleaned filter and the brushes are still not rotating
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 02, 2008
Brush head will not spin. Canister is completely clean yet no rotation to be seen.
If cleaning the brush bar really well doesn't solve it you may want to replace the filters. If that doesn't work you may need to replace the brush head.
Feb 16, 2016 | Dyson DC05 Bagless Canister Cyclonic...
Brush is not spinning on the pet hair power brush
Those things work off of suction, which spins a cog wheel that rotates and spins brush via a small belt. Disassemble the brush and check belt. Make sure the apparatus is clean and free of debris
Jul 25, 2015 | Euro-Pro Shark SC-505 Handheld Steam...
BRUSH NOT SPINNING ON A DYSON DC44 ANIMAL
Hi Veronica,
Thank you for reaching out. I am sorry to hear your brush bar will not rotate. In light of the detail you provided regarding the spindle there are a few checks we need to complete in order to determine the best solution. Please call our Helpline to speak with an expert.
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Dec 17, 2013 | Dyson Animal Bagless Cordless Hand Vacuum,...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes do not rotate. It is not the filter.
Hi There,
When the brushes stop spinning, this indicates either that your spin scrub brushes are dirty and need cleaning, or that the internal turbine assembly has gone bad. Unfortunately this problem is widespread on Hoover SteamVac's.
No worries though, I have written a detailed diagnosing of this problem, and explain step by step how to fix it.
Please visit the link below:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you have any follow up questions, or would like further help, please just add your question to the comment or clarification request form here on Fixya, and I'll be more then happy to help.
Thanks,
Chris Jones
GoVacuum.com
Jun 01, 2010 | Hoover F5906-900 Upright Steam Vacuum
Roomba 550 dust bin always empty but filter and brushes always need cleaning. doesn't seem to clean as well as in the beginning
Sounds like you either have a very clean floor, and only dust remains OR, you have dust and baby powder on the floor clogging the hepa filter. THIS time wash the filter with water, then check for blockage in your waste gate area.
Feb 22, 2010 | iRobot Roomba 550 Vacuum
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes wont turn
Remove the brush block, turn the unit on its side and watch the square hole to see if it rotates. If not, then the turbine(#23) isn't working, if it is, then is the shaft on top of the brush block broke off, if it is, replace the brush block.
Jul 01, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
177 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
