I am installing a True Steam Humidifier on a Climatemaster TTV064 watersource heat pump. Does the outdoor sensor have to be installed for the humidifier to work properly.
Hire a certified heating specilist and pay for the installation. When you do, you are not only paying for the installation but you are paying for the many years of knowledge that goes into his or her carrer,
Yes you will want the out door sensor. The reason why is it is going to read the average temp outside and will adjust what you hum is producing due to the temp outside, that is so you dont cause condensation on your window. You can run it in manuel or auto but i would strongly reccomend to run it in auto.
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem...
(More)
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem exists- Thanks, Richard
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on...
(More)
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on "Leave" at 58 degrees at 7am and "Return" at 66 degrees at 4pm. The unit starts heating the house at 12noon to move it 8 degrees. According to the directions it should only kick on a max of 24 minutes per degree not 4 hours - any suggestions?
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and...
(More)
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and humidity. what could be wrong?
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to...
(More)
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to outside temp,and the blower turns off ,the humidifier water still comes into humidifier and wont shut offf unless i turn humidistat to off position
