Question about Dometic Rooftop RV Air Conditioner
Rooftop A/C The A/C compressor is coming on but the fan will not. Unit is 3 years old.
  • 182 Answers
Fan motor or capacitor.could be a control issue.better call a pro.
Posted on Jul 04, 2008
2 Suggested Answers
  • 127 Answers
SOURCE: Compressor doesnt come on in a dometic duotherm
If this is a wall thermostat controlled unit, then check to make sure that you have power coming from the yellow wire on the thermostat when it is placed in the Cool/Auto High mode. If you do not have power at the yellow wire, then you have a bad thermostat. If you do have power, then remove the control unit from the inside of the AC and see if you have power at the Y terminal there. If so, when you turn the thermostat to cool, can you hear a relay clicking in the box? If not, then you have a bad control box. If the relay is clicking, you need to check the power at the compressor relay on the board. It has a black wire to one side and a purple (or blue) wire on the outgoing side. Check to see if you have 120V on the blue wire when the tstat is set to High/Cool. If not, then you need to bypass the freeze switch to make sure that is not the problem. If you do, then you need to go upstairs and check the start capacitor for OK. It is located in the side compartment of the upper unit, it has a small black relay on the top called a PTCR. These often burn out and will cause the compressor not to work. If that is fine, then you go to the top of the compressor to the thermal overload switch. See if you have power at both sides, if so, then you have a bad compressor. If not, then the overload switch is open and not allowing power to the compressor.
Posted on Jul 04, 2009
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
We have royal red furnace to heat our home.The fan dose not stop.
Details.......does the furnace function normally otherwise? Might just be a stuck fan switch. Make sure the thermostat hasn't been set on Fan ON setting or summer air circ. on older furnaces.
Find the fan switch and tap it and see if fan quits. If it does,fan switch is bad.probably. Always make sure your air circ. filter(return air to furnace) is replaced every 3 mo. or so,too. don-ohio (:^)
Jan 03, 2017 | Royal Heating & Cooling
Replaced ac unit with new compressor. Fires up as usual but compressor wont start.No fault code coming on controller. Whats the problem?
possible causes include
excessive gas
low gas
relay not working,
faulty thermostat
faulty start/run capacitor
bad circuit board
Jan 03, 2017 | Heating & Cooling
Why does my home A/C unit result in a constant stream of water coming out of the overflow drain? I've had the same unit for 5 years, and it seems that it drains water in ever-increasing amounts. Als
Sounds like it is freezing up. Kind of hard to say since you did not say whether it is a central heat and air system. My overflow was constantly draining onto my patio from overflow. I crawled up in the attic and followed the pvc pipe where it came in from the outside and closer to the central unit in the attic I drilled a hole in the 90 degree elbow of the pvc and unclogged the pipe which was frozen from running so long. Then I covered the hole with silicone. no more leak coming from overflow
Dec 27, 2014 | Heating & Cooling
Is it cost effective to replace draft inducer blower on 22 year old furnace?
Depends on the cost to repair. Probably a 22 year old furnace is not very efficient also. Take every thing into consideration.
If it still works it may work for a while but you don't want a break down in the middle of winter.
Nov 07, 2014 | Heating & Cooling
Williams wall heater setting off co2 alarm
Then it may well need a service or check the alarm
Jan 01, 2014 | Williams (5009622) Ceramic Gas Wall...
A/c fan not working=thermostat is working(central a/c system)a/c
The fan on the outside unit is powered from it's 240 volt source. Check that the breaker for the outside unit is not tripped. Also, a contactor is inside the outer unit that starts the fan - it may be faulty.
Jul 26, 2008 | Friedrich QuietMaster Electronic SS12J30D...
Dometic Rooftop RV Air Conditioner Logo
69 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
